Lucas RF 95 voltage regulator modification.
PostPosted: Tue Jan 19, 2021 11:58 pm    Post subject: Reply with quote
DM. That diagram is very helpful. I hope I can follow it correctly.
You are most kind to help me understand what has always been a mystery to me.
The only problem is that A3 is not live. Because the normally closed contact on the left coil was not closed I thought I had better disconnect the coils altogether. I de soldered them from their vertical stakes and linked the stakes together with a thick wire.
I presume it will be O.K. to take a link from A1 to A3?
DM
PostPosted: Wed Jan 20, 2021 8:48 am    Post subject: Reply with quote
A3 will not be live, it is also switched by the ignition relay so the accessories only work with the ignition on which is how it worked when new.
If you link from A1 to A3 you will bypass the ignition switch and the relay so the coil and accesories will be permanentley live.
PostPosted: Wed Jan 20, 2021 9:40 am    Post subject: Reply with quote
O.K. That makes sense. Thanks again.
Have a safe day.
PostPosted: Wed Jan 20, 2021 5:41 pm    Post subject: Reply with quote
As the alternator and ignition switch relays are sited next to each other I have taken the opportunity of combining their ground wires as a matter of neatness and economy.
Is there any reason why the wire from terminal 85 from one relay should not be linked to T85 from the other in a similar fashion?
DM
PostPosted: Wed Jan 20, 2021 7:04 pm    Post subject: Reply with quote
You can link T85 from both relays together and feed them with 1 wire from the ignition switch, would make a tidier installation.
PostPosted: Wed Jan 20, 2021 7:43 pm    Post subject: Reply with quote
Excellent! That is just what I want to achieve. Very Happy
PostPosted: Wed Jan 20, 2021 9:19 pm    Post subject: Reply with quote
So do these two relays do more than protect the alternator and ignition switch?
I am particularly keen on protecting the electronic distributor. Will it require a separate relay?
PostPosted: Wed Jan 20, 2021 9:38 pm    Post subject: Reply with quote
Ray , a relay won't protect the alternator or electronic distributor, it simply moves the load from a switch to the relay, so only "protects" switch contacts.
PostPosted: Wed Jan 20, 2021 10:22 pm    Post subject: Reply with quote
What I understood was that the diode in the relay prevented stray high voltage spikes from damaging electronics.?
PostPosted: Wed Jan 20, 2021 10:27 pm    Post subject: Reply with quote
Its the relay coil itself that generates the high voltages (back EMF) , hence the precaution in fitting a diode across the coil.
PostPosted: Wed Jan 20, 2021 10:40 pm    Post subject: Reply with quote
I am still on a steep learning curve!
I will presumably need a relay if I am to protect the ancient horn button.? The same switch incorporates a headlamp dip switch. Will it be the horn or the headlamp relay that protects the dipping function?
PostPosted: Wed Jan 20, 2021 11:19 pm    Post subject: Reply with quote
Ray
I'm no electrician, but just for clarity, a relay is little more than a remote switch to carry a heavy current, triggered by a switch designed for a light current.
In early cars, a relay is often used for the horn, occasionally the headlights & little else.
Introducing a relay into a circuit that doesn't really need it adds another point-of-failure. An arbitrary value might be 5 amps; any device that consumes less is adequately handled by a dashboard switch, anything more might be a candidate for a relay.
Personally, I would not add a relay to a critical ignition circuit.
2002 MINI Cooper 'S'
PostPosted: Thu Jan 21, 2021 12:28 am    Post subject: Reply with quote
MVPeters wrote:
Ray
I too would like to avoid failure if possible. I have been advised to protect the ignition/lighting switch with a relay from someone who had four of them fail before doing so. The horn/dip switch is also vulnerable...
PostPosted: Thu Jan 21, 2021 11:27 am    Post subject: Reply with quote
MVPeters wrote:
Ray
Ray I presume you have the Lucas PLC combined ignition/charge/light switch? They tend to get warm with the headlights on full beam, and if the contacts are worn get hot hence the fire risk. So worth adding a relay to the headlamp circuit but not for anything else related to the switch. Horns don't usually present a fire risk as the are only used momentarily, however they do draw a relatively large current that will wear the contacts, so adding a relay will increase reliability.
When I was a know it all youth Embarassed I bought a Bedford CA for £60, it really needed new dampers and track rod ends, but instead I decided it require a set of air horns! The air horn set came with a relay, but in my youthful arrogance I thought this was unnecessary complication so simply wired them into the existing horn wiring. The high current required to get the air horn spinning was clearly to much for the van horn switch, which resulted in the compressor taking a couple of seconds to get up to speed, resulting is a gurgling's /squawking sound until the full blast was achived!
PostPosted: Thu Jan 21, 2021 11:58 am    Post subject: Reply with quote
No Dave. I do not have that switch. The one I have is a Lucas PRS3 not normally found on MG. (See my dashboard thread). I shall not be changing it for a PLC with this instrument cluster.
(I have a PLC switch on an 'original' design dashboard that will not be fitted).
Page 2 of 3
