Google Aeroplanes
PostPosted: Wed Feb 10, 2021 9:02 pm    Post subject: Google Aeroplanes Reply with quote
I've never seen a jet plane in flight on Google maps before.
https://goo.gl/maps/DhJL1zSRAKhi5rQH9
PostPosted: Wed Feb 10, 2021 9:23 pm    Post subject: Reply with quote
Neither have I, I suppose if you look deeply enough over major air routes there must be a few to discover
PostPosted: Wed Feb 10, 2021 10:45 pm    Post subject: Reply with quote
I have found them over the years on G Earth by following the approach paths for runways.
It is easier if you can rotate the view to make the runway r to l on your screen because a gentle nudge with the mouse will then just track the view in a straight line.
The orientation control seems to have disappeared from my version of G Earth.
If you pick up one on the approach you will often also see it's shadow on the ground.
The higher altitude aircraft are often discovered because people spot the vapour trails.
