Gearbox Oil
PostPosted: Mon Mar 01, 2021 9:50 am    Post subject: Gearbox Oil Reply with quote
Question, my 1942 Commer handbook quotes the gearbox oil as 'Shell EP Spirax Heavy', would that be EP 90 or EP 140?
What do you think?
PostPosted: Mon Mar 01, 2021 10:36 am    Post subject: Reply with quote
Offhand I'm not sure on the weight, but EP can cause problems if there are any bronze bushes in the gearbox iirc - best check to be sure.
PostPosted: Mon Mar 01, 2021 11:15 am    Post subject: Reply with quote
Yes Rick, I have been advised against the EP oils. The WD oil grade in the book is C600, I have now been reliably informed the modern equivalent is SAE140 which is safe for use with yellow metals.
