UKdave2002 Guest
Posted: Thu Jul 12, 2007 12:53 pm Post subject: Splitting Brake Calipers |
In many workshop manuals there is a very clear statement along the lines of; “Under no circumstances should the brake caliper be split” …why?
Splitting makes servicing calipers so much easier, it’s not complicated; there is usually an “O” ring which may be as old as the car and would benefit from being replaced. Yes you have to re-assemble the calliper correctly under scrupulously clean conditions, torque the bolts correctly and check it all seals and hold pressure, but this is no different to working on other components in the hydraulic system.
So why the dire warning ?
Posted: Fri Jul 13, 2007 4:04 pm Post subject: |
It was pointed out to me a few years ago, that 'scrupulously clean' in terms of hydraulics is not the same as what most people mean by scrupulously clean.
The minimum air quality in the room has to be what is known as 'Hepa clean,' which I understood to be the next step down after sterile.
I wish someone would explain the reasoning behind this better to me!
UJ |
magic9r
Posted: Sun Dec 14, 2008 5:55 pm Post subject: |
Given the amount of crap that gets pushed through the caliper from deteriorating systems plus that which forms in a caliper that's total BS.
The two main reasons are:-
1 - No one will advise you to split them because they don't want the liability for what might happen if they came apart again in use and they cannot assess your competence to do the job.
2 - The industry has a vested interest in selling you a new or recon part, some places are now refusing to sell caliper service kits on liability grounds but will get you an exorbitantly expensive exchange unit, undoubtably precision built in a clean room by some 18 year old gimp with a vocational qualification and neat clean fingernails.
Go figure,
Regards,
Nick |
Posted: Tue Dec 16, 2008 1:56 pm Post subject: |
| I worked for Lucas Girling for several years and calipers were assembled on a standard production line, not in some clinical clean room. The O'ring replacement makes sense, so might replacing the bridge bolts with new high tension ones, but so long as you use the same care that you would for say a head gasket, I see no reason why a caliper should not be dismantled for servicing |
TriumphDriver
Joined: 22 Jan 2021 Posts: 11 Location: Northern Ireland
Posted: Sun Apr 18, 2021 5:44 pm Post subject: |
Does anyone know the torque they should be retightened to? _________________ Still learning after all these years... |
Joined: 14 Oct 2016 Posts: 2132 Location: East Yorkshire
Posted: Sun Apr 18, 2021 7:47 pm Post subject: |
I had [and probably still have, somewhere?] a few sets of calipers for the Skoda Rapid [rear engine jobbie, not the VW lookalike!]...
For homologation reasons, Skoda fitted 4 piston calipers to the Rapid 136....[unlike on the Estelle which had a single piston caliper]
These 4 piston calipers were actually quite small, ie compact.
A lot more difficult to overhaul[free off?] than the Estelle jobbies.
However, the calipers were dismantlable [ as per the manuals]....they came apart and O rings etc had to be renewed, etc.
Plus, splitting the caliper really was the only way to deal with the pistons and bores.
As with nearly every component on the old rear engine Skoda's, they were designed to be taken apart, and put back together. The brake fittings especially were a delight, being proper threaded banjos, etc...on everything...so trip round the scrappy at teatime could yield a carrier bag full of banjos from just one car! [At the time, a banjo from a proper brake factor could be 3 or 4 quid, or more!!!] _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Wed Aug 04, 2021 7:20 pm Post subject: |
The square section o-ring ‘gallery seals’ can be difficult to find by application. They don’t generally come in the repair kits. However, most Girling calipers use one, most Lockheed another, etc. They can easily be ordered by quickly measuring the recess where the seal sits.
If going to the extent of replacing all the pistons and seals, I would always split them (once the pistons are out) as it makes it much easier to clean, and to check the galleries are clear from crud. I have seen totally blocked ones before, so exercise caution. _________________ Richard Hughes |
