dazdawn2007
Posted: Tue Jan 01, 2008 3:26 pm Post subject: painting under mgb gt |
well its now getting near the time for the prep/paint time for the underside of the car now. what tips can you give on this ie, what to prep with and also what to paint on. cheers  |
Posted: Tue Jan 01, 2008 5:16 pm Post subject: |
Do not use Hammerite/Smoothrite as it dires too brittle. If you want it to match the car colour as it may have done originally at least in parts a alkyd-based coach enamal is the best preferably over some stone chip shutz.
If you want it to last then cover the whole lot with black Wayoyl shutz. Paint balck chassis bits with Chassis Black
This assumes all rust has been cut out or stabilsed and sealed _________________ Rover P2
Joined: 23 Nov 2007 Posts: 4240 Location: South Cheshire
Posted: Wed Jan 02, 2008 11:30 am Post subject: |
This may help, its the wax injection points for the MGB. All holes should be injected.
