Miken
Posted: Mon Mar 21, 2022 8:10 pm Post subject: Antifreeze |
I learnt something today which you may already know. If you didn't, you are welcome.
2 years ago I filled up my cars cooling system with Bluecol 2 year antifreeze.
It's now time for a coolant change.
I have a 5 litre container full of leftover 50/50 antifreeze and water that I mixed up 2 years ago but haven't used.
I wasn't sure if this 2 year old mix would still be useable.
I contacted the manufacturer and it turns out it's ok to use.
Now you know. |
norustplease
Posted: Tue Mar 22, 2022 6:50 pm Post subject: |
Good information.
It is probably the repeated heating and cooling in the engine wich degrades it whilst in use. I must admit that I have a couple of cans of antifreeze that are a couple of years old and I had wondered whether they were still usable. _________________ 1953 Citroen Traction
1964 Volvo PV544
1957 Austin A55 Mk 1
Boring Tucson SUV |
Kenham
Posted: Tue Mar 22, 2022 8:01 pm Post subject: |
I may be totally wrong but I think this is a complete con changing the antifreeze every couple of years. I have machines that have had the same antifreeze in for 35 plus years and have never had any problems. What can degrade or is it the case the modern antifreeze is just not up to a good standard. My Defender 300tdi has had the same antifreeze for the last 10 years at least with no problems , I will stick with it being a con .  |
Posted: Tue Mar 22, 2022 8:14 pm Post subject: |
Kenham wrote: | I may be totally wrong but I think this is a complete con changing the antifreeze every couple of years. I have machines that have had the same antifreeze in for 35 plus years and have never had any problems. What can degrade or is it the case the modern antifreeze is just not up to a good standard. My Defender 300tdi has had the same antifreeze for the last 10 years at least with no problems , I will stick with it being a con .  |
I'm with you Kenham . It seems like a waste to throw out perfectly usable anti freeze. Is there a test that anyone could do to check the concentration level? I find that the Range Rover requires the occasional "topping up" but when it does I am unlikely to have a mixed solution to hand so it just gets a drink of water but there is a risk that the protection levels could be compromised. |
lowdrag
Posted: Tue Mar 22, 2022 9:53 pm Post subject: |
I have never drained and changed the antifreeze, just drained a drop or two and added some neat to the radiator. But the car overheats in hot weahter and blows out half a litre when hot so all I am doing is replacing lost coolant. A never ending circle. |
Posted: Tue Mar 22, 2022 10:34 pm Post subject: |
I think I will get one of those testers. Makes sense.
Interestingly, I learned something today; that pure antifreeze has a much higher freezing point than a 50/50 mix. Ethylene glycol freezes at 6 degrees F apparently.
(I am not too proud to admit when I didn't know something. I have a saying; "you don't know what you don't know") |
Miken
Posted: Tue Mar 22, 2022 11:42 pm Post subject: |
When I rebuilt the engine 2 years ago I spent several days digging and clearing out all the hard rusty deposits that were obstructing the water gallery.
I was shocked at the amount of rubbish I removed. Areas that I thought we're solid metal turned out to be blockages and were hammered out using old screwdrivers and poked at with bits of welding wire.
This work would not have been possible with the engine in the car.
I put this down to years of previous owners not changing the coolant very often or at all.
This is why I've decided to keep to the manufacturer recommendations.
I'm less concerned about freezing. |
