Rich5ltr
Joined: 28 Mar 2008 Posts: 681 Location: Hampshire, UK
Posted: Mon Oct 24, 2022 9:45 am Post subject: Re: Lagonda |
| bjacko wrote: | An old friend of mine used to work for Lagonda making the mudguards and other panels by hand. No presses in those days. Sadly he passed away a couple of years ago.
Have you converted your "D" tail lights to LEDs to reduce the risk of some clown running into the back of you? If not you can buy kits from Classic Dynamo and Regulator Conversions which fit the lights perfectly and are much brighter than the originals. see their website at www.dynamoregulatorconversions.com | No but that's definitely on the list of things to do this winter so thanks for the link.
Just to be safe I fitted a bicycle led rear light on the spare wheel for the run down to Goodwood and back. |
Crashbox
Posted: Mon Oct 24, 2022 10:56 am Post subject: |
I'm wanting to convert the Minor's lighting (6v system) to LEDs. Having used the little Morris in the dark I can honestly say the original lighting is woeful at best. Out in the sticks without any other traffic around it's just about decent enough to keep the car bowling along at 40mph, but as soon as a vehicle approaches from behind their headlights swamp the area and casts such a dark shadow of my car ahead of me that my headlamps might as well be off. _________________ 1989 2CV
1932 Morris Minor S.V. Two-Seater |
Posted: Mon Oct 24, 2022 12:46 pm Post subject: |
| Crashbox wrote: | | I'm wanting to convert the Minor's lighting (6v system) to LEDs. Having used the little Morris in the dark I can honestly say the original lighting is woeful at best. Out in the sticks without any other traffic around it's just about decent enough to keep the car bowling along at 40mph, but as soon as a vehicle approaches from behind their headlights swamp the area and casts such a dark shadow of my car ahead of me that my headlamps might as well be off. |
That is what I found when driving the Dodge; only the Dodge being a big car it has consequently a bigger shadow.!
It seems to depend on how bright the following car's lights are and how close they get. Often they wanted to overtake because the Dodge was quite slow ( but not as slow as my Austin Swallow which is mechanically an Austin Seven)... but being a big car they had to wait until there was a suitable gap.
With the little Austin, they tend to squeeze by.
I have invested in halogen headlamp bulbs for my MG TC. Personally, I feel they are perfectly bright enough and have a much better beam spread than LEDs which don't work that well with old fashioned reflectors...but each to their own, I suppose. |
Crashbox
Posted: Mon Oct 24, 2022 8:21 pm Post subject: |
The most recent innovation are LED headlamp bulbs with their own reflectors built into the body of the bulb. So if you have headlamps that are 90+years old and the reflectors are not in great condition, it doesn't matter from a functional point of view. _________________ 1989 2CV
Posted: Mon Oct 24, 2022 10:00 pm Post subject: |
| Crashbox wrote: | | The most recent innovation are LED headlamp bulbs with their own reflectors built into the body of the bulb. So if you have headlamps that are 90+years old and the reflectors are not in great condition, it doesn't matter from a functional point of view. |
I had not realised there was a solution like that.
Thanks. |
Posted: Tue Oct 25, 2022 10:32 am Post subject: |
When I changed a few years ago I could find perfectly acceptable 5 watt equivalents for side lamps and instrument panel. Headlamp LEDs were not as good as the filament lamps but a big advantage for night time town driving. I couldn't find any LEDs that were as good as the usual 22 watt brake light bulbs so I've stuck with the originals for them.
http://www.nostalgiatech.co.uk/LED%20Lighting.htm
Peter. _________________ https://www.nostalgiatech.co.uk
Crashbox
Posted: Wed Oct 26, 2022 10:21 pm Post subject: |
Thanks guys there are clearly a lot more choices of LED bulbs since I converted.
Rich5ltr
Posted: Thu Oct 27, 2022 9:04 pm Post subject: |
| Crashbox wrote: | | The most recent innovation are LED headlamp bulbs with their own reflectors built into the body of the bulb. So if you have headlamps that are 90+years old and the reflectors are not in great condition, it doesn't matter from a functional point of view. | Are they a warm white or that inappropriate brilliant white? |
Rich5ltr
Posted: Thu Oct 27, 2022 9:07 pm Post subject: |
| I've read that there are often issues with LED bulbs in vintage (and PVT) cars because they draw such little power that they don't overcome weak earths and poor connections. ANy thoughts? |
Posted: Thu Oct 27, 2022 9:58 pm Post subject: |
| peter scott wrote: | Thanks guys there are clearly a lot more choices of LED bulbs since I converted.
Peter |
Yes, like electric cars, LEDs are an emerging technology. There's quite a way to go. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
bjacko
Joined: 28 Oct 2013 Posts: 534 Location: Melbourne Australia
Posted: Fri Oct 28, 2022 5:42 am Post subject: Lights |
It is essential with all bulbs to have a good earth. When I ordered a new loom I specified earth wires for all lights. Never had any trouble since but years ago back in UK I had earth problems because the car relied on earthing through the various body parts and with rust developing in the body joints the connections were not the best. Got a bit of fright one night when cruising along an unlit country road and suddenly the lights all went off and luckily two minutes later they came back on. Never able to find the cause but when I got time I improved the earthing.
The LEDs above sound ok but they are 58 mm long and may not fit all cars. |
Crashbox
Posted: Fri Oct 28, 2022 9:45 am Post subject: |
| Rich5ltr wrote: | | Crashbox wrote: | | The most recent innovation are LED headlamp bulbs with their own reflectors built into the body of the bulb. So if you have headlamps that are 90+years old and the reflectors are not in great condition, it doesn't matter from a functional point of view. | Are they a warm white or that inappropriate brilliant white? |
In the link I posted, there are bulbs available in both. There's even a bulb that emits a yellow light for classic French vehicles. _________________ 1989 2CV
