Siddeley Special Six - the stuff of legend.
PostPosted: Fri Nov 11, 2022 8:10 pm    Post subject: Siddeley Special Six - the stuff of legend. Reply with quote
Obviously not cheap; these were the car of choice for those in the know when they were new.
Imagine the joy of owning one today.
https://www.carandclassic.com/car/C944424
https://www.kautschuk-klassik.com/fahrzeuge/armstrong-siddeley/siddeley-special-six/
Bengt Axel
PostPosted: Fri Nov 11, 2022 8:32 pm    Post subject: Reply with quote
Totally wonderful and that that price a (comparative!) snip.
"Once bread becomes toast, it can never go back!"
PostPosted: Fri Nov 11, 2022 9:34 pm    Post subject: Reply with quote
I thought so.
That's not to say there may not be some hidden problem awaiting a hopeful but unsuspecting buyer.
Having said that, I would jump at the chance if for no other reason than you only live once. Very Happy
One issue that seems to have plagued this car - like so many others these days - is down to the dreaded petrol evaporation. I noted the pipe to the carb is wrapped; presumably in an attempt to prevent it. A more permanent solution might be to have the exhaust manifolds ceramic coated.?
PostPosted: Sun Nov 13, 2022 10:01 am    Post subject: Reply with quote
I have wrapped part of my petrol pipe in the engine compartment. Not a major problem but can fluff if stuck in traffic with little flow in the pipes.
An Australian friend has a rather better solution. He has arranged a small pipe to feed unused fuel back to the tank. Keeps the fuel circulating.
PostPosted: Sun Nov 13, 2022 11:56 am    Post subject: Reply with quote
I agree.
Unless one is going to source that very expensive fuel that has the same constituents as fuel of the 1950's, then adaptations need to be considered to enable an od vehicle to run on today's fuel.
Peter's answer is something even more modern owners around the world have resorted to in order to keep their old jalopies running on modern fuel.
Another consideration may be the fitment of an electric fuel pump?
There is a reason why modern cars with EFI run electric pumps instead of mechanical ones...
An additional benefit of an electric pump fitment is the ability to refill the carburettor float bowl without churning the engine over first..
Modern fuel can reduce its volume by evaporation of head end components quite rapidly, if the engine isn't run on a regular basis.....
PostPosted: Sun Nov 13, 2022 1:17 pm    Post subject: Reply with quote
As a matter of interest, isn't there a return to the tank on cars with fuel injection?
Modern fuel systems without a fuel return line have a pressure regulator incorporated into the pump which is in the tank.
