Joined: 23 Nov 2007 Posts: 4766 Location: Swindon, Wilts.
Joined: 26 Jan 2012 Posts: 1740 Location: Above the snow line in old Monmouthshire
Posted: Sun Apr 09, 2023 9:26 pm Post subject: |
It's a new one to me, I wonder what the tracks are for? |
Posted: Sun Apr 09, 2023 10:02 pm Post subject: |
...and a strange RSJ poking out of the wagon over the turret top.? |
BigJohn
Posted: Mon Apr 10, 2023 8:40 am Post subject: |
Ray White wrote: | ...and a strange RSJ poking out of the wagon over the turret top.? |
I always thought this moved to provide a lifting point for using block and tackle. _________________ 1974 Mk1 Escort. |
Posted: Mon Apr 10, 2023 9:13 am Post subject: |
The dolly must be powered via some sort of PTO, otherwise there would be no point in having tracks?
Possibly for recovery over rough/ soft terrain and or where the recovered vehicle had damage? |
Posted: Mon Apr 10, 2023 9:47 am Post subject: |
ukdave2002 wrote: | The dolly must be powered via some sort of PTO, otherwise there would be no point in having tracks?
I think the dolly being powered by PTO is a good shout. But if the ground is soft, how is the recovered vehicle to be lifted sufficiently to get the dolly underneath the axle, and how does the tow vehicle not also get stuck? There are more questions than answers with this one! |
Posted: Mon Apr 10, 2023 10:29 am Post subject: |
I agree there is a PTO but the tractor unit would have to be very carefully geared to the 6WD wouldn't it? |
Posted: Mon Apr 10, 2023 11:15 am Post subject: |
Could the dolly be just a load spreader?
After all the sort of small wheels you normally see on an ambulance are only about the size of the track wheels on this and a larger ambulance wheel would require A) A higher lift and B) the rear of the towed vehicle being nearer to grounding on rough terrain roads, particularly if it has a long rear overhang.. _________________ Bristols should always come in pairs.
Posted: Mon Apr 10, 2023 11:23 am Post subject: |
Bitumen Boy wrote: | ukdave2002 wrote: | The dolly must be powered via some sort of PTO, otherwise there would be no point in having tracks?
Possibly the visible “RSJ” is the end of a crane jib that extends out of the rear to lift the stranded vehicle? |
Posted: Mon Apr 10, 2023 12:17 pm Post subject: |
The dolley looks like an attempt to achieve low ground pressure to me.
The bar, I don't think, is attached to a PTO. It looks like an ordinary 'straight bar', used to achieve a rigid tow, since the casualty's brakes would not be active.
The RSJ extends to the rear to provide a lifting capability.
See link below?
https://www.keymilitary.com/article/trouble-trucks-and-trailers _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Mon Apr 10, 2023 1:55 pm Post subject: |
alastairq wrote: | The dolley looks like an attempt to achieve low ground pressure to me.
See link below?
https://www.keymilitary.com/article/trouble-trucks-and-trailers |
Thinking about it you are probably right about the dolly not being powered, it would require a lot of additional engineering, a tracked trailer could probably be made narrower and lower that a wheeled dolly, and as you point out spreads the load. |
Posted: Mon Apr 10, 2023 1:59 pm Post subject: |
See link below?
I think you are right, Alastair. If you had a PTO attached to a dolly with tracts like that it would be fighting the 6WD lorry unless it had gearing of some kind. |
consul 57
Posted: Tue Apr 11, 2023 12:15 pm Post subject: |
the picture is in the book breakdown about recovery in the british army
the dolly is called a tracked ambulance and the austin is breakdown version with an rsj to hang the pulley block from to lift engines and fronts of vehicles for towing suspended or with the un powred dolly, which is from ww2, the pic is from the 50's.
the army experimented with several tracked recovery trailers in pre & during ww2. |
Posted: Tue Apr 11, 2023 1:16 pm Post subject: |
The RAF had a similar idea, with their aircraft recovery dollies.
{ Tracjacs?}
A link to a web page, various excellent photos after scrolling down, plus excellent user-based descriptions of purpose.
https://hmvf.co.uk/topic/9078-tracked-aircraft-recovery-dolly/ _________________ Dellow Mk2, 1951 built, reg 1952.
