Joined: 30 Apr 2013 Posts: 4248 Location: The Somerset Levels
Posted: Thu Apr 06, 2023 12:15 pm Post subject: |
I like it. I remember reading that when Rootes took over, the 4 litre carried on being hand built in the traditional way. It would have been an up market car in it's day ...and may well have a surprising turn of speed.
Very nice.
https://www.carfolio.com/sunbeam-talbot-4-litre-44440 |
Posted: Tue Apr 25, 2023 1:37 pm Post subject: |
I don't think the car sold, I have seen it since advertised at £11.5k. _________________ Various Rootes Vehicles. |
Posted: Tue Apr 25, 2023 2:58 pm Post subject: |
| Try and find another one in that condition. IF it had been available when I sold the Dodge I would have bought it. No problem. |
Posted: Tue Apr 25, 2023 5:40 pm Post subject: |
| Rick wrote: |
I spy a Dauphine in the background too ...
RJ |
I would only consider one of those cars if it was post 1960 with the revised suspension. Earlier models had a reputation for loosing control on bends. |
Joined: 20 Aug 2008 Posts: 1486 Location: Netherlands
Posted: Wed Apr 26, 2023 9:21 am Post subject: |
| Ray White wrote: | | Rick wrote: |
RJ |
How often would that happen. I think the situation may be well different with modern (radial) tyres.
The Herald / early Spitfires have a flawed rear suspension which will only present itself in extreme cases. It would not (and did not) put me off buying a car with that less than perfect rear suspension. _________________ a car stops being fun when it becomes an investment |
Posted: Wed Apr 26, 2023 9:23 am Post subject: |
Would you also rule out a Riley Pathfinder then Ray?
Lovely cars, but also with a flawed rear suspension. _________________ a car stops being fun when it becomes an investment |
Posted: Wed Apr 26, 2023 10:28 am Post subject: |
| badhuis wrote: | | Ray White wrote: | | Rick wrote: |
RJ |
The Herald / early Spitfires have a flawed rear suspension which will only present itself in extreme cases. It would not (and did not) put me off buying a car with that less than perfect rear suspension. |
I cut my teeth with wayward early Spitfires so it wouldn't worry me much either to be honest. A Gordini Dauphine would be very welcome here!
Posted: Wed Apr 26, 2023 11:16 am Post subject: |
Those early Dauphines were always rolling over...and you didn't need to be going fast either. The reason Renault redesigned the suspension was because they were becoming a joke! No joke if you were in one I imagine.
The Pathfinder suffered from the most dreadful understeer and gained the nickname "Ditch finder".
Again, the later cars benefited from rear suspension redesign; in that case getting semi elliptic rear springs ...but by then the cars had got a bad reputation. These days, I imagine modern radial tyres would help a bit.
As a matter of little interest, my Dad was great mates with the Pathfinder designer Gerald Palmer - and because he was so famous, he could do no wrong!  |
Posted: Wed Apr 26, 2023 7:16 pm Post subject: |
Back in the days before a mixed tyre arrangement became illegal, we had a Vauxhall 6cyl with the big hydraulic front suspension system. On cross plies it had a tendency to wallow down the road and understeer, but we stuck a pair of radials on the front only and although it didn't stop the soft ride bounce, it changed the steering completely, it didn't oversteer but if you put it into a corner you could actually let go of the wheel and it just stayed on the same lock; obviously this meant that you hadf to bring the wheel back to straight manually it just wouldn't self centre.
When they changed the law I was one of the few people who understood why. _________________ Bristols should always come in pairs.
Joined: 23 Nov 2007 Posts: 4296 Location: South Cheshire
Posted: Wed Apr 26, 2023 8:19 pm Post subject: |
| Penman wrote: | Back in the days before a mixed tyre arrangement became illegal, we had a Vauxhall 6cyl with the big hydraulic front suspension system. On cross plies it had a tendency to wallow down the road and understeer, but we stuck a pair of radials on the front only and although it didn't stop the soft ride bounce, it changed the steering completely, it didn't oversteer but if you put it into a corner you could actually let go of the wheel and it just stayed on the same lock; obviously this meant that you hadf to bring the wheel back to straight manually it just wouldn't self centre.
When they changed the law I was one of the few people who understood why. | as far as I’m aware it’s on illegal to mix tyre types on the same axle? |
Posted: Wed Apr 26, 2023 8:57 pm Post subject: |
It's illegal to have radials on the front and cross plys on the rear.
https://tinyurl.com/Tyre-Mix _________________ Bristols should always come in pairs.
