Posted: Sun Jun 04, 2023 9:25 pm Post subject: |
I just don't see the point. It deserves to remain unsold.
I suppose it could be broken for parts? |
Joined: 31 Jul 2009 Posts: 1819 Location: Market Warsop, Nottinghamshire
Posted: Mon Jun 05, 2023 8:02 am Post subject: |
Why create such a poorly-fitting bonnet extension, and then pay for a 'professional respray'?
'Essentially needs finishing, hence the low price' - in other words I can't get it registered, you try! _________________ in the garage: a big empty space!
Joined: 14 Oct 2016 Posts: 2160 Location: East Yorkshire
Posted: Mon Jun 05, 2023 2:22 pm Post subject: |
| Quote: | | 'Essentially needs finishing, hence the low price' - in other words I can't get it registered, you try! |
It is recorded on DVLA site, with the V8
Wholely inappropriate engine for that sort of car, in my book.
No mention of how the rear axle [or, back axle ?] has been uprated or changed? _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Mon Jun 05, 2023 3:36 pm Post subject: |
...if I might add...probably the best place for the 3.5 litre Rover V8 is either in a Rover,,, Range Rover,,, or ultimately a Morgan...
Morgan Plus 8. Now there's a car to be reckoned with...
I know it's a Buick engine but I like it. I wonder how many +4 Morgans have become +8s?? |
Joined: 20 Aug 2008 Posts: 1486 Location: Netherlands
Posted: Mon Jun 05, 2023 6:02 pm Post subject: |
| Ray White wrote: | ...if I might add...probably the best place for the 3.5 litre Rover V8 is either in a Rover,,, Range Rover,,, or ultimately a Morgan...
Many I suppose.
I d not have a problem by fitting another engine in a car (all Jensens have a non-Jensen engine), even Rover fitted the Buick engine as you say. Some Jaguars used Standard engines before WW2, many more examples to be found.
But it has to fit and not by making an awful extension to the front of the car!
Also I feel the engine should at least be from the same period the car was made. But all in my opinion, anyone can do what they like - which sometimes might result in these awful monsters! _________________ a car stops being fun when it becomes an investment |
bjacko
Joined: 28 Oct 2013 Posts: 554 Location: Melbourne Australia
Posted: Tue Jun 06, 2023 7:33 am Post subject: Wolseley V8 |
Why would you bother. _________________ 1938 Morris 8 Ser II Coupe Utility (Pickup)
1985 Rover SD1 VDP |
Posted: Tue Jun 06, 2023 9:13 am Post subject: Re: Wolseley V8 |
| bjacko wrote: | | Why would you bother. |
... because there is no accounting for taste...
Joined: 23 Nov 2007 Posts: 4296 Location: South Cheshire
Posted: Tue Jun 06, 2023 11:25 am Post subject: |
Its hideous , reminds me of a sandal worn with a sock! |
Posted: Tue Jun 06, 2023 12:15 pm Post subject: |
| Quote: | | I wonder how many +4 Morgans have become +8s?? |
Probably not that many....if any at all?
IIRC, before the Wawer, Morgan tried a Ford flathead V8 in the 4/4 chassis....Found it to be 'incredible' up the Morgan ''test hill'' out of Malvern.
The downside was, Ford wouldn't supply the 'right' V8 engine!
IIRC, also, I believe Morgan made a special for his daughter.... a drophead coupe which might have contained the flathead V8?
My memory isn't too good these days [is it really brown bin day?] and I haven't got my Morgan books to hand at resent, to check.
Morgans always used someone else's engines [and gearboxes, in the 4 wheelers]...Coventry Climax, followed by the ''Standard Special' motor [different to Jagwar's Standard engines]... Ford sidevalve [1172cc]...Triumph and Standard big engines [2.2 litre, 2 litre]...which upset Triumph's boss, as Morgans, with his engine, were faster than the Triumphs, and cheaper to boot.. Then there were the Ford OHV engines, crossflows, etc....FIAT twin cams, Rover V8s, etc etc etc....
Nowadays they are all a bit handbaggy for my tastes. _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Tue Jun 06, 2023 1:27 pm Post subject: |
The Plus 8 is basically a Plus 4 with a Rover V8.
Admittedly the chassis would need to be modified as per the original ... and the body widened slightly ... but I would think it is eminently feasible.
I expect the biggest difficulty would probably be getting it registered and insured.  |
Joined: 30 Apr 2013 Posts: 4248 Location: The Somerset Levels
Posted: Tue Jun 06, 2023 4:03 pm Post subject: |
When I see something like that it really does make me wonder what people are thinking... _________________ Various Rootes Vehicles. |
Posted: Tue Jun 06, 2023 4:43 pm Post subject: |
| Rootes75 wrote: | | When I see something like that it really does make me wonder what people are thinking... |
That's just it; they are not!
As it happens, there is room in the Wolseley engine bay for the Rover V8. Several conversions have been done quite well ...without the need for an extension. |
bjacko
Posted: Wed Jun 07, 2023 6:39 am Post subject: Wolseley V8 |
The Rover V8 is no longer than most straight 6 engines but it is wider. It has proven to be a very good engine fitted to many car makes as original. _________________ 1938 Morris 8 Ser II Coupe Utility (Pickup)
