'Barn find' Mark 6 Bentley.
PostPosted: Thu Jul 13, 2023 12:05 pm    Post subject: 'Barn find' Mark 6 Bentley. Reply with quote
Now then...
This looks interesting. Obviously the date is wrong but that aside, but this might just be a sleeper. If the bidding is depressed it could be a cheap entry into the rarified world of Bentley motors. Be prepared to add on the cost of new radial tyres and battery for starters.
Ashley loved his Mark 6 (what ever happened to Ashley?)
I know one would need to spend quite a bit to get her back on the road but this looks to me like an honest old car.
Some potentially serious issues:
Is the engine free?
What is the issue with the missing radiator cap and fan belt?
No paperwork. How difficult would it be to get a new V5?
Underneath? I have seen worse!
https://www.mathewsons.co.uk/auction/lot/lot-198---1956-bentley/?lot=16211&so=0&st=&sto=0&au=46&ef=&et=&ic=False&sd=0&pp=96&pn=3&g=1
PostPosted: Thu Jul 13, 2023 1:42 pm    Post subject: Reply with quote
Good old bus indeed.
Shame about the fuel consumption of these tho, for regular daily useage ? { Although a couple of decades ago one was regularly used by a villager where I lived....tatty, but useable. }
A viable alternative to using as a daily, a Series Land Rover, perhaps?
PostPosted: Thu Jul 13, 2023 2:59 pm    Post subject: Reply with quote
I was thinking if I could keep it under cover, I could use it as a replacement for my P38. I don't do many miles now so fuel consumption would be less important than in the past.
I do know the pitfalls. My Dad once explained how the cylinder bores were hard chromed which makes a re bore expensive. On the other hand, the chances are that a new set of rings and valve grind alone would probably solve a smokey exhaust; something I could manage.
They do have a tendency to rust badly; especially underneath. This is largely due to the poor quality steel that even Bentley had to contend with in the aftermath of WW2. If not too bad, a good Waxoil would do no harm.
This is one of the 4 1/2 litre 'big bore small boot' cars with several improvements over the original 4 1/4 litre cars such as a full flow oil filter and twin exhausts... but if it was only the later R type that benefitted from the high speed axle I am not sure?. In any event, it is a useful modification that can be carried out at home as a straight 'pumpkin' exchange is available. The original gearing does tend to be too low for today's motoring needs and so a high speed rear axle is popular among Mark 6 owners.
There is another Bentley in this auction - an R Type - from the same location ...but it would be too long. The Mark 6 at just 16ft whichfit nicely in my garage!
What attracted me to this particular car is that it looks like one that could be used and gradually improved - assuming it can be made to run in the first place! Laughing
PostPosted: Thu Jul 13, 2023 9:09 pm    Post subject: Reply with quote
The registration is on the DVLA database as a 1956 Bentley so a new V5 should be no problem.
PostPosted: Thu Jul 13, 2023 9:35 pm    Post subject: Reply with quote
Does it not matter that the Mark 6 was only built between 1946 and 1952 ?
PostPosted: Thu Jul 13, 2023 11:27 pm    Post subject: Reply with quote
Quoted from a certain partisan website:
Bentley 4¼ litre:
This engine has overhead inlet and side exhaust structure with an aluminium cylinder head held to a cast iron block with 3 rows of studs. Like the Jaguar 3½ litre there is no water circulation around cylinders 2 and 5. A number of design elements can cause problems. Bypass oil filtering and unfiltered rocker feed can limit bearing life and the unusual use of chrome cylinder liners that only extend part the way down the cylinders tends to cause a step at the transition resulting in havoc with the rings but the most serious weakness is probably due to the design of the water circulation within the block. This tends to cause localised overheating problems at the exhaust valves and can lead to cracks between the exhaust valve seats and the cylinders.
Bentley 4½ litre:
This engine is very similar to the 4¼ litre but doesn't suffer from the smaller engine's bypass oil filtering, however the larger bores only serve to accentuate the cylinder and overheating issues.
Peter Wink
PostPosted: Fri Jul 14, 2023 8:47 am    Post subject: Reply with quote
It does look like a very good basis as a rolling project. Also a good entry as you say into this market of car...
PostPosted: Fri Jul 14, 2023 9:39 am    Post subject: Reply with quote
Thank you Peter.
I can't say I haven't been warned, can I?
As I said, my Dad warned about the partial chroming. It would explain why he was so annoyed about the rebuild cost.
Then there are the overheating issues.
No quick fixes with these engines, then! Embarassed
NB. On closer examination I am not sure this is a 4 1/2 litre version. The fresh air vents which should be in the lower scuttle are absent as is the second exhaust pipe ...which all indicate a somewhat less proficient and earlier 4 1/4 car. The earlier cars have a single flap vent under the windscreen; omitted on the big bore cars. This has just the one flap.
Truth be told, what with an incorrect date and no paperwork, Mathewson's don't really know what they are selling. Rolling Eyes
Should I raise the issue with the Auctioneers? ...or just leave it to someone else Question
(Mark 6 chassis restoration)
https://www.youtube.com/watch?v=OUs_gN4KTcc
PostPosted: Sat Jul 22, 2023 11:32 am    Post subject: Reply with quote
Mark 6 Bentley sold for £9,600.
Bargain?
Of course, it might be a lemon. Some have cost £100K to restore to concours Shocked (if that is your thing Confused )
PostPosted: Sat Jul 22, 2023 11:29 pm    Post subject: Reply with quote
Anyone on here being the highest bidder??
PostPosted: Sun Jul 23, 2023 9:16 am    Post subject: Reply with quote
Jean would have lynched me. Shocked
Laughing
(Incidentally, having re read Ashley's blog I discovered that the corrosion above the windscreen could indicate that the body has been re mounted incorrectly with the back sinking and trying to pull the roof off at the front !! Shocked
PostPosted: Mon Aug 21, 2023 10:26 am    Post subject: Reply with quote
...and at the other end of the scale...
https://www.carandclassic.com/car/C1623567
I know it is expensive but this lovely example is not as high priced as some. Importantly, there is a detailed article from the previous long term owner here...
https://www.kda132.com/b40pv-a-wolf-in-sheeps-clothing/
It just shows, I think, what can be done.
I like the idea of the similar (but better) S1 4.9 litre engine to transform the performance.
PostPosted: Mon Aug 21, 2023 4:48 pm    Post subject: Reply with quote
KDA 132 belongs - or did belong - to "Ashley", a former frequenter of this parish.
PostPosted: Mon Aug 21, 2023 5:33 pm    Post subject: Reply with quote
Exactly. I did ask earlier what ever happened to him? We seemed to enjoy a bit of banter from time to time. Despite our differences over hot rods I always had great respect for his abilities.
A read of the article by Giles Usher reveals that he purchased the restored S1 4.9 engine from Ashley.
There are two benefits of the S1 in the Mark 6.
1) no more worries about the chrome cuff liners which have proved to be catastrophic in the 4.2 and 4.6 engines.
2) A substantial increase in performance which transforms the performance of these delightful cars.
PostPosted: Sun Aug 18, 2024 11:49 pm    Post subject: Reply with quote
Bangers and Cash (repeat) caught up with 'Hi 6663' some time after the sale. It has found a new home with a nice, down to Earth couple; Sam and Elizabeth, who live on the Suffolk coast.
Retired blacksmith, Sam, has put some work in to return the Mark V1 to good, usable order. He admits to having noticed a difference from the Morris 1000 cars that he usually works on and has had to "read the book several times on this one"...but he is in no way intimidated by the Bentley.
He is, however, having to get used to the gear lever being in the way when getting in and out. It has a habit of getting caught in one's trouser leg and as Sam says "it leaves a lot to be desired, really".
Sam and Elizabeth are enjoying their 'new' motor; although Elizabeth says she would need a cushion to see over the steering wheel if she were driving! She says it is very elegant and very comfortable and helps Sam by operating the indicators switch in the middle of the dashboard. "You have to remember to switch them off again" she said.
Elizabeth says the Bentley makes them smile when they go out in it ...and she sees other people smile when they see it. "It is a happy car" she said.
Sam intends to take the Mark V1 to the village show; although he freely admits to not being fond of "sitting about talking to people about cars".
Personally, I think this was a real bargain; it even has a complete tool kit that lives in a locked compartment of the dashboard.
Very Happy
