Rusty
Joined: 10 Feb 2009 Posts: 272 Location: Bunbury, Western Australia
Posted: Sat Nov 11, 2023 7:38 am Post subject: BMC "B" Series rocker arm querie ! |
Can anyone tell me if 4 cylinder "B" series rocker arm assembly's are interchangeable ?
A friend has an approximately 1950 A 40 Devon based station wagon (countryman, I think you call them in UK), which has several flogged out rocker bushings and as such has probably damaged the shaft. I have several sets of rockers I can give him to repair it, but they are either to suit early 1200cc A 40 engines, or later 1800cc engines. His A 40 has at some time had a 1600cc engine and a taller diff put into it, so will either the early or the later rockers fit on an in-between engine. I don't know what the engine originally came out of, but I suspect either an A55 or series 2 Oxford.
Thanks blokes,
Graham in Western Australia. |
Posted: Sat Nov 11, 2023 12:57 pm Post subject: |
Hi Rusty,
I believe the three bearing BMC motors had interchangable rockers. I am not sure about the five bearing 1800 motors. The 1800 block was slightly longer than the three bearing motors. The orginal 1200cc A40 engine was NOT a 'B' series BMC. It was the basis for the 'B; series, but parts are not interchanable as far as I know.
My A40 tourer has a Austin A60 motor fitted. (1620cc)
1950 Austin A40 tourer
1999 BMW Z3
Posted: Sat Nov 11, 2023 1:59 pm Post subject: |
Keith D wrote: |
Keith |
Sounds like it's a pocket rocket!!  |
Rusty
Posted: Sun Nov 12, 2023 2:14 am Post subject: |
Keith D wrote: | Hi Rusty,
Keith |
Thanks Keith,
"Yoos lurns somethink knew every doy ifn yous lissns !"
Seriously, "Thanks", I do have a 1600 engine in a series 2 Oxford and also an old Morris Major elite with whatever they had but only one of both, and I was hoping to hang onto those, but if he needs them, he can definitely have them. Neither of them is ever likely to be resurrected by me, so it's probably better that at least some parts are used,"somewhere" !
Michael, (the owner) didn't know if the head was the original or whether the new engines head was on the engine when installed. The previous owner told him of the exchange of the "block" but never said if the head was original or not. From what you have said, I gather that the cylinder heads on the 1200 would be unique to that engine, so the rockers, shaft and pedestals are also most likely unique as well, but the later heads would likely swap between different displacement engines. Do you know if the Elites engines are the same as the 1600s, or are they the same as the 1800s ? I didn't know there was a difference in the size of the blocks, I knew about the crankshafts but thought the rest of the engines were the same. Is the "Elite" engine three bearing or five ? it might make a difference to which set I remove for him ! How can you tell the difference between a 1500, 1600 and 1620, I only looked at his engine briefly last weekend, and never took notice if it is cast into the block, and my own engines are up at the farm 300ks away so its not easy to compare to them.
Graham |
Miken
Posted: Sun Nov 12, 2023 10:21 am Post subject: |
I run a 1954 A40 with the original type 1200cc engine which I rebuilt. I also own a 1500 B series engine that I have also rebuilt that I might (but probably wont) get round to fitting one day.
I can confirm that there are no interchangeable parts between the 2 engines. Even the threads are different BSF vs UNF.
Whilst superficialy similar the B engine is about 20mm longer and different in many other respects.
I suppose the spark plugs could be interchanged. |
Posted: Sun Nov 12, 2023 1:20 pm Post subject: |
Rusty,
The Morris Major and Austin Lancer were fitted initially with the 1500cc Series 'B' engine. The Major Elite and the very last of the Lancers were fitted with the 1620cc series "B". Almost all parts between the various 3 bearing series "B' engines were interchangable. The crankshafts were interchangable so the pistons were obviously not.
The series "B" three main bearing was available in 1200cc, 1500cc and 1620cc. I don't think there was actually a 1600cc. Engine size is embossed in the crankcase casting down towards the sump, from memory on the passenger side.
For UK forum folk, the Major and Lancers in Oz were BMC cars very similar bodily to the Wolseley 1500 and the Riley 1.5, but they were very basic. No wooden dashboards etc! The Major had a grill that went across the front of the car. The Lancer had a grille very similar to the Riley. The last Major Elite grew fins on the rear guards as cars were liable to do in about 1960.
1999 BMW Z3
Rusty
Posted: Mon Nov 13, 2023 1:19 am Post subject: |
Thanks Keith, it's good to get some input from someone who not only knows the marques normal details but also the things that were peculiar to Australia in otherwise well known "British" vehicles.
Michael is currently in New South Wales, and won't be back for several weeks, but when he returns, I will get him to have a look for the capacity marks on the block so I can give him the correct set to use.
Miken, Thanks also to you for confirming in more detail what Keith "suspected"! It looks like the 1200cc engines are only useful to someone with an original A 40.
Thanks to you both for taking the time,
Graham
PS
I would go out and have a look now myself to find out the size engine, but the "other half" has just come down with the current wave of covid, so I suspect I will be housebound for several weeks until its run its course with the pair of us ! |
Posted: Mon Nov 13, 2023 10:53 am Post subject: |
Rusty,
I had a look at my engine this afternoon to confirm where the engine size is shown. It is embossed on the passenger side of the engine near the front above the engine mount.
Regards - Keith _________________ 1926 Chrysler 60 tourer
1999 BMW Z3
Posted: Mon Nov 13, 2023 11:13 am Post subject: |
Ray,
The A40 tourer is not quite a pocket rocket as you suggest.
Because we have pretty empty roads outside of Perth I wanted a car that would cruise at 'modern' speeds. If I want to go into the city I use the train or bus which is free for us oldies. I do a fair bit of country driving in the A40 and I don't want to be all day getting to my destination.
To get the longer legs, I also replaced the diff with that from an A70 which gives me a true speed of slightly over 60km/h when the existing mph guage shows 30mph. (60 km/h = 37 mph which is our built up area speed limit.) From this you can see that the car has much longer legs when on the open road but decreases the acceleration to around that of the 1200 engine and original diff.
Wherever you go in Western Australia, its a long way, so you need a car with a decent cruising speed. The state speed limit out in the sticks is 110km/h (=68mph) My Austin can cruise happily at around 100km/h. I also fitted Austin A70 brakes which are 11" diameter drums, so she can stop better than with the originals.
1999 BMW Z3
Penguin45
Posted: Mon Nov 13, 2023 11:36 am Post subject: |
The 1600 "B" series was the twin cam, briefly and disastrously fitted to the MGA. Actual capacity was 1588cc. The other engines were 1498, 1622 and 1798.
Lyndsay Porter "BMC and Leyland B-series Engine Data" ISBN 0-85045-597-9 is the go to work for all things B series.
Posted: Mon Nov 13, 2023 11:37 am Post subject: |
Hi Keith. I have started watching a TV series with Bill Bailey who is exploring Western Australia. It looks absolutely fantastic.
The A40 with higher gearing must be much more suitable for your roads. That the acceleration is not brilliant is not really an issue. Once you are up to speed you can expect to continue for ages on those roads!! |
Posted: Mon Nov 13, 2023 12:42 pm Post subject: |
Yes Ray,
I really appreciate our open empty WA roads, especially after spending the month of May this year driving the length and breadth of traffic choked Britain.
1999 BMW Z3
Posted: Mon Nov 13, 2023 12:58 pm Post subject: |
Keith D wrote: | Yes Ray,
Regards - Keith |
Personally, (and this is not being political) I believe the problem with Britain; in particular England is that we have a population crisis. You often hear people say we have a congestion crisis, a housing crisis, a crisis in the NHS, Education, Policing, pollution, etc. etc. etc.... but the one thing that is never questioned is unsustainable procreation. Add to that ever increasing immigration and it is not surprising that we have traffic congestion.
It's a wonder we don't sink beneath the waves.!  |
Posted: Mon Nov 13, 2023 4:22 pm Post subject: |
Ray White wrote: | Keith D wrote: | Yes Ray,
Regards - Keith |
I tend to agree with you, Ray; but not just England or the whole UK, it seems pretty obvious to me that the whole world has a human population crisis with too many people competing for ever scarcer resources. Politicians talk about ever more draconian "green" policies but really what is needed is a great uptake in contraception. Interestingly, people seem to have realised this for themselves in many parts of the world as birth rates are falling and politicians are worried about falling populations as a result, and the consequences of ageing populations... the cynic in me thinks they're more worried about not having enough young people to conscript to fight in WW3 that so many of them seem to want to start.
I don't seem to be alone in this, but I long ago realised I didn't want to be a father because I didn't want to bring a child into this world to go to the same sorts of lousy schools that I went to, studying for pointless qualifications that nobody wants just to end up being hassled by the dole or doing the same sorts of crappy jobs like I've been doing these twentysomething years now... I just can't see any future for young people now unless they're very lucky or have very rich parents.
Edit: sorry for drifting waaay off topic...  |
Posted: Mon Nov 13, 2023 5:01 pm Post subject: |
Yes, sorry...I think that's my fault. We have drifted a long way from Rusty's original question. I was interested to see if rocker shafts were interchangeable but as Miken has confirmed they are not. |
