Thor Copper mallet
PostPosted: Thu Sep 07, 2023 11:34 pm    Post subject: Thor Copper mallet Reply with quote
I am thinking about buying a copper mallet but there are a several diferent sizes to choose from. What would be the best size for tightening wheel spinners?
(I have rubber and wooden mallets but have never owned or even used a Thor Copper mallet)
PostPosted: Sat Sep 09, 2023 7:10 am    Post subject: Reply with quote
After ruining many a spinner over the years, this is the perfect answer - the Thor Dead Blow mallet. Nylon face, lead shot inside which enforces the effect but does not damage the spinner. About £30
PostPosted: Sat Sep 09, 2023 8:30 am    Post subject: Reply with quote
Thank you Lowdrag. Nice bit of lateral thinking.
PostPosted: Sat Sep 09, 2023 9:19 am    Post subject: Reply with quote
BAck in the early 70's last century, I had a Sprite with wires and knock-ons.... I also had a Thor mallet...The sort with a nylon insert one end, and a very soft metal insert in the toher.
The Nylon end was useless for hitting in the ''undo'' direction. [Wasn't it an American who thought the make of the car was ''Undo?'']
The ears needed a good solid blow to get them shifting.
Trouble was, the ears [bless BMC] were actually chrome plated [brass?] and the chrome soon started to split off after a few punctures.
PostPosted: Sat Sep 09, 2023 10:04 am    Post subject: Reply with quote
I could always make one of these, I suppose?...
PostPosted: Sat Sep 09, 2023 3:05 pm    Post subject: Reply with quote
I believe that Thor copper/hide hammers are OE for a number of British car manufacturers.
I purchased one of those for my MGA, IMHO they are not up to the job and wouldn't last many wheel changes, I use a Thor hammer, using the hide side for 95% of tightening, and a final whack with the copper side with a bit of card sandwiched between the spinner and hammer to (try) to protect the spinner chrome, whilst not original, as lowdrag suggests, the dead blow, with lead is probably the better option.
PostPosted: Sat Sep 09, 2023 3:45 pm    Post subject: Reply with quote
Thank you Dave. Good to get other people's suggestions.
Clactonguy
PostPosted: Fri Feb 02, 2024 9:51 am    Post subject: spinners Reply with quote
never used ir had dealing with a wheel spinner situation. they do look good though. surprised each end has no hole though as would probably simply have a thickish ? ( 17mm) bar shoved in and the bar used as impact /wrench sort of thing acting as lever to spinners. rubber plug in holes to stop mud ingress etc .
PostPosted: Fri Feb 02, 2024 10:04 am    Post subject: Reply with quote
I also bought one of these wooden things but it was not useful at all. Being multiplex the layers separated after only a few hard blows. Maybe if it was made of solid wood it would work.
