Humber Sceptre exhaust issue
Brewster
PostPosted: Fri Apr 26, 2024 11:04 am    Post subject: Humber Sceptre exhaust issue Reply with quote
Would anyone happen to have a drawing or photograph of a Sceptre Mk2 exhaust system? My car has a rear silencer that's more holey than the Pope. It's beyond repair.
I was wondering if an exhaust from a modern car might be persuaded to donate a rear section but the Sceptre is in a tight lock-up which my 23-year-old self might have been able to access for a butchers but my 63-year-old self can't get near. I can't push the car out because I wouldn't be able to push it back in again. Needless to say, it's not drivable at the moment.
So if anyone could post an illustration of the Mk 2 exhaust or has any idea whether there's a modern car whose rear silencer might be sort of interchangeable I'd be very grateful.
Bruce
PostPosted: Fri Apr 26, 2024 12:04 pm    Post subject: Reply with quote
I'll try to remember to ask my mate at the weekend if he has any old exhaust catalogues, that might show enough to figure out the silencer dimensions.
PostPosted: Fri Apr 26, 2024 12:14 pm    Post subject: Reply with quote
Hello Brewster. I assume you will need to extract the car at some point? Why not get a friend or two to help get the car out so you can work on it then perhaps they could help push it back in when you are done.
I personally would join an owners club and see if they had a spare exhaust. If they can't help supply one they will have met the problem before and probably have a solution.
You may need to get an exhaust system made. I have used Gough's with good results. https://www.pdgough.com
bjacko
PostPosted: Sat Apr 27, 2024 7:40 am    Post subject: Exhaust systems Reply with quote
Some of the older exhaust system makers may still have the drawings or samples
1985 Rover SD1 VDP
PostPosted: Sat Apr 27, 2024 10:30 am    Post subject: Reply with quote
Brewster
PostPosted: Sat Apr 27, 2024 11:09 am    Post subject: Reply with quote
Thanks for all the replies and especially to Peter for the illustration. That's very useful although the pipe that kicks up over the rear axle might be a problem.
I reckon it would be about ?200 - ?300 to have a custom piece made locally which I'm reluctant to spend until I've decided whether or not I'm going to keep the car.
In the meantime I've been given permission by a local exhaust fitter to help myself to any silencers in his skip that might be usable so I'll monitor that for a few weeks just in case.
Brewster
PostPosted: Sat Apr 27, 2024 11:18 am    Post subject: Reply with quote
Sorry about the repeated replies. The system kept throwing up error messages as soon as I hit submit and it didn't appear that my reply was being published.
PostPosted: Sat Apr 27, 2024 11:44 am    Post subject: Reply with quote
If your error message is the DEBUG one, just ignore it. Go back to the category start, click through to your topic and 99.9% of the time your post will be there.
petelang
PostPosted: Tue Apr 30, 2024 8:50 am    Post subject: Reply with quote
Whereabouts are you Bruce? I might have something that would suit.
Daimler V8 250 1969
Brewster
PostPosted: Thu May 02, 2024 5:11 pm    Post subject: Reply with quote
I?m in St Andrews.
petelang
PostPosted: Fri May 03, 2024 8:51 pm    Post subject: Reply with quote
Long way from Nottingham then.
Daimler V8 250 1969
