Posted: Tue Oct 01, 2024 8:03 pm Post subject: Never seen this before... |
In tonight's episode (repeat) of a Saab 900 turbo, Fuzz Townshend discovered that one of the a big end bearing shells had been forced into the cap on top of the existing shell. NOT GOOD!
I have not seen this before and wondered just how rare this disaster is ??
Anyone come across it before.?
I was surprised to find such an event on a Saab 900 16 valve engine which to my mind is one of the all time greats and capable of phenomenal mileages. I suppose it is an example of what can happen if overheating issues are ignored. |
V8 Nutter
Posted: Wed Oct 02, 2024 8:48 am Post subject: |
| I worked at an engine reconditioners for 20 years, I have seen it many times. The first time was in a Ford V8 with fully floating shells. It usually happens when one shell ceases on to the crank. |
Posted: Wed Oct 02, 2024 9:20 am Post subject: Re: Never seen this before... |
| Ray White wrote: | | I was surprised to find such an event on a Saab 900 16 valve engine which to my mind is one of the all time greats and capable of phenomenal mileages. I suppose it is an example of what can happen if overheating issues are ignored. |
I guess it doesn't matter how good an engine is, if the oil is old and dirty the bearings are going to give up sooner rather than later. |
Posted: Wed Oct 02, 2024 10:55 am Post subject: |
Seeing the CAR SOS team restore a Saab 900 reminded me that it was car I always wanted in the day but for one reason or another I never did get one.
I then thought about my friend's situation and wondered if they could do a rebuild on his wife's 1973 Triumph Stag which - for health reasons - has not been restored. It is a rare magenta model.
On further investigation I discovered that they will not take on cars that they have already restored ...and the 7th car they rescued was a Triumph Stag.
Joined: 14 Oct 2016 Posts: 2149 Location: East Yorkshire
Posted: Wed Oct 02, 2024 2:23 pm Post subject: |
Having owned a couple of SAAB 900's....one a turbo model [HP]....whilst they were 'nice' cars to drive, I found them rather tank-like in the road manners......quite the opposite to the Lotus theory.
Plus, they seem to suffer from droopy headlining syndrome...[the glue unglues itself] and as a result, were a beggah to put right.
So a droopy head lining would put me reet orff having one today... _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Thu Oct 03, 2024 4:50 pm Post subject: |
| Rick wrote: | I'd have another 900 Turbo one day. In fact I know of one sat on a driveway, looks surprisingly solid with slightly faded paint. Common sense says stay away.
RJ |
I quite like the soft top ...but I dare say it would be a bit too flash for me!  |
Posted: Thu Oct 03, 2024 10:05 pm Post subject: |
| Ray White wrote: | | Rick wrote: | I'd have another 900 Turbo one day. In fact I know of one sat on a driveway, looks surprisingly solid with slightly faded paint. Common sense says stay away.
RJ |
Doesn't scuttle shake blight them a bit? Ideally it'd be a flat-nosed 16S 3dr in silver for me, but they rarely come up for sale.
Vintage Fly Guy
Posted: Sat Oct 05, 2024 10:20 am Post subject: |
A sagging headlining is usually an easy enough fault to fix on an 80s to modern day type car, as long as the correct colour and cloth type can still be sourced. It's often not a particularly expensive job to have done either (providing it's not overly complex to strip the car down to remove the headlining to re-cover it); earlier this year it cost me 380 quid + VAT to get the headlining on my 92 Range Rover Classic re-covered, with the work carried out by a leading RR specialist car trimmer.
Compare that to the cost of having just one bodywork panel repaired/replaced and resprayed and I'll take a saggy headlining any day of the week!
However, as we know, cars can vary, so get a quote from a trimmer who specialises in that particular make and model, so you know what to expect cost-wise before buying something that looks like the inside of a Bedouin tent!
Interestingly, while people tend to blame the glue for failing and causing a headlining on an 80s to modern day car to sag, it's often the thin layer of backing foam on cloth that perishes, rather than the adhesive. Once the backing foam starts turning to breadcrumbs there's little choice other than to replace the cloth lining, unless you like drawing pins and the Chesterfield sofa look! |
Posted: Sat Oct 05, 2024 1:27 pm Post subject: |
Headlinings can be fairly easily removed from SAAB 900s providing they have a tailgate.
Yes, the thin foam backing is the culprit....
However, ?380 + vat, would have been, and still is, completely out of my price range. I think I paid less than that for the 900 turbo?
I did manage to sort out the 900 auto's headlining [which was my personal favourite to drive...the Turbo really did feel like an ocean going tug to drive....despite it's ''speed'' capabilities....which were, and still are, somewhat irrelevant in today's traffic environment.]
A large carton of spray glues, and several really fine days saw it done, using the original, but cleaned [both sides] material, and new under-material. The stiff backing was in good condition too, which helped.
The Turbo was another story entirely.
My attempts to fix that headlining [not drooping quite so badly as the auto's]...resulted in an explosion, amongst other issues.
I had ordered another carton of spray glue, but it arrived whilst everybody was out of the house [rural living for you]...and the courier put the box inside a very neat condition Skoda Estelle that I had been 'given'....
Quite why, I'm not sure...it wasn't amongst the instructions left on a note pinned to the house door!
But it was one of the hotter days of that summer....and the glue decided to explode in splendid fashion, inside the Estelle....Whilst nobody was 'in!'
The rocket propelled glue grenades took out the windscreen, the sunroof, andalso managed to penetrate the doors...luckily not getting through the outer door skins.
There was dinosaur snot everywhere...
I ended up parting with the car for the same price I paid [nowt],, but in a far less decent condition.
I managed to salvage just enough unexploded glue to more or less fix the Turbo's lining.....and parted with it to some poor unwitting begger in MAnchester... _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Sat Oct 05, 2024 1:31 pm Post subject: |
I did manage to sort out the 900 auto's headlining, which was my personal favourite to drive...the Turbo really did feel like an ocean going tug to drive....despite it's ''speed'' capabilities....which were, and still are, somewhat irrelevant in today's traffic environment.
A large carton of spray glues, and several really fine days saw it done, using the original, but cleaned , material, and new under-material. The stiff backing was in good condition too, which helped.
It was one of the hotter days of that summer....and the glue decided to explode in splendid fashion, inside the Estelle....
The rocket propelled glue grenades took out the windscreen, the sunroof, and also managed to penetrate the doors...luckily not getting through the outer door skins.
There was dinosaur snot everywhere... _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Sat Oct 05, 2024 1:32 pm Post subject: |
However, ?380 would have been, and still is, completely out of my price range. I think I paid less than that for the whole 900 turbo?
Posted: Sat Oct 05, 2024 1:33 pm Post subject: |
They took out the windscreen, the sunroof, and also managed to penetrate the doors...luckily not getting through the outer door skins.
Posted: Sat Oct 05, 2024 7:06 pm Post subject: |
| One thing about modern trim to watch out for are the plastic clips. Supposing you can find them (and they are often hidden) they may be marque specific and require special tools to prevent them from snapping. In fact some fasteners are single use and will need to be renewed. |
Vintage Fly Guy
Posted: Sat Oct 05, 2024 9:47 pm Post subject: |
| Ray White wrote: | | One thing about modern trim to watch out for are the plastic clips. Supposing you can find them (and they are often hidden) they may be marque specific and require special tools to prevent them from snapping. In fact some fasteners are single use and will need to be renewed. |
A good point well made. Hence me choosing a RR specialist trimmer to sort my headlining; if the trimmer knows the model inside out (literally!) and is working on them every day then I figured there'd be much less chance of them breaking or forcing and distorting something, and any clips, studs, etc. that did succumb to age-related brittleness would be held in stock if needed.
I could have had a go myself but I thought it would be an expensive mistake if I'd ordered the cloth and then made a bugger of it, and I tend to be a perfectionist, so there's every chance I wouldn't have been happy with the finished job if I'd got so much as a small crease or a smear of glue on it!
Also, there's the sheer size of a one-piece headlining on a '90s Range Rover Classic, which would have required setting up some sort of enormous temporary table in the garage to support it while I stripped the old fabric, cleaned all the foam remnants off and re-covered it. If it had been the two-piece version then I might have been more tempted by a DIY project. That one-piece headlining backing structure is so large I'm surprised that criminal gangs haven't tried selling them to would-be migrants to try and cross the channel on! |
