Joined: 30 Apr 2013 Posts: 4168 Location: The Somerset Levels
Posted: Sun Mar 09, 2025 9:07 pm Post subject: Vintage Tyres |
With the cost of vintage tyres a friend of mine was saying today about fitting modern equivalents...
I'm after a set of 5.60x15 but he's saying 155R15 will fit?
Anyone out there taking this option on their classics? _________________ Various Rootes Vehicles. |
Posted: Mon Mar 10, 2025 8:41 am Post subject: |
Its exactly what I did with my Bedford CA, purists don't like it! as well as the cost saving the steering is much better  |
Joined: 14 Oct 2016 Posts: 2116 Location: East Yorkshire
Posted: Mon Mar 10, 2025 10:19 am Post subject: |
On on of mine, the wheels are ordinary sidevalve Ford, 16 inch...Normally the rears had 5.00/5.50 x 16 fitted....but I have had success with 175/80 x 16 [taxi] tyres....primarily Michelin XC4S....[as have many others]
I haven't tried them on the front wheels, as they take a 450 tyre [narrower than rears]..
But the FSOC have reported that owners have fitted 175/80 x 16s to fronts of saloons, with good effect.
The 'taxi' type tyre has a stiff sidewall [is it 6 ply?] so quite closely follow the characteristics of a cross ply tyre.
Nankang FT7 tyres of the same size, although intended for modern so-called soft roader vehicles, have more flexible [2 ply?] sidewalls...and need their white lettering disguised somehow.
An issue with the fitment of radial tyres to oldies might be, whether they might catch bodywork? Or affect steering lock if on the fronts?
Also, will the increase in stiction make problems for old technology suspension and steering components?
[Much as the fitting of disc brakes to pre-war front axles can lead to torque reaction issues?] _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Mon Mar 10, 2025 11:17 am Post subject: |
By sheer coincidence, I have been reading about how some people have been fitting radials in place of cross ply tyres to their MG TCs.
As UKDave has pointed out the purists don't like it; in fact, the subject has caused quite a bit of angst among T type owners in the USA. The reason is because although the Bridgestone radials transform the handing they have a lower profile which corresponds to a lower the ride height. The tyre in question (normally fitted to a BMW electric car) basically changes the look of the car on the road.
Personally, I made the mistake of ordering 5 new wheels and 'Waymaster' cross ply tyres early on in the restoration. The mistake was in failing to realise that regardless of type, the clock is ticking from the date of tyre manufacture . I have lost half my tyres' life before even going on the road! |
Posted: Tue Mar 11, 2025 9:54 am Post subject: |
Ray White wrote: | ...
So long as they're well stored, dry, out of sunlight etc I wouldn't go just off the date stamp personally.
Posted: Tue Mar 11, 2025 10:06 am Post subject: |
Rick wrote: | Ray White wrote: | ...
RJ |
I am uncertain about the legal position. Is it something a busy body hobby Bobby might be able to report you for? |
Norseman
Posted: Tue Mar 11, 2025 10:40 am Post subject: |
RJ[/quote]
I am uncertain about the legal position. Is it something a busy body hobby Bobby might be able to report you for?[/quote]
To the best of my knowledge there is no legal issue with the age of car tyres, only condition & tread depth. It never ceases to amaze me that just 1.6mm across 75% of the tread width is still considered adequate in law, I change mine at 3mm. Tyre manuf. recommend renewing tyres at 8 years, but then they have an axe to grind !
Obviously driving on outdated rubber isn't a good thing, especially in the wet, but common sense on the owner's part should prevail. _________________ 1987 classic Range Rover Vogue auto
1998 E39 523i SE auto sedan
A great many models have served me well since the 'sixties, all of them old & some even older than me. |
Posted: Tue Mar 11, 2025 12:58 pm Post subject: |
As Norseman says, for cars, no current legal requirement regarding age of tyres...Different rules for goods vehicles, taxis and buses, however.
Aside from cracks in the sidewalls [which might fail an MoT if one could be bovvered?]....the major change one would notice is with the 'hardness' of the rubber itself.
I mention an incident that happened a few years back in the Manchester area, where a gent was driving his MGB, and it crashed.
At the time I believe the cause was contributed to, by the car having tyres with very good tread, but which were several decades old. [Pirelli Cinturato, I believe?}
When I ran a Daihatsu 4Trak on next to nowt budget, I would sometimes buy the huge tyres[relatively, in my world]....off ebay.
The size being the awkward factor for the 4Trak!
Some of them, good quality makes [Dunlop, as it happened]...I discovered had been recovered from scrapped Vauxhall Frontieras....off the spare wheel....which would have been located on the back door, exposed to sunlight & the elements for the life of the vehicle before being scrapped.
In both cases [I only bought two, as it happened.] I found the tread [as new in appearance and depth]..started to peel away from the carcass....after not too many miles. So swapped them out. I used them on the rear axle anyway, and before anybody climbs on nearby high horses....I don't have any faith whatsoever in tyres of any make whatsoever..as too much can go awry .....My working life, and skills acquired, mean I still , even now, drive consciously, placing zero faith on what's under me backside...simply being highly aware of what is going on downstairs. Yup, I even do pressure checks every day or so [I don't always drive every day now I'm a pensioneer...]...as, living where I do, there is so much greater chance of picking up a nail, or screw [my latest puncture]...or very sharp stone due to the narrow width of the roads I use, and the need [I like to help those innocent motorists coming the other way]....to sometimes take to the verge, of broken road edge, to allow those less able to conduct their blobbymobiles with the needed accuracy........
I don't like to wait until a tyre has lost 10 psi before I do anything about it... Can't afford to replace willy-nilly.
[Anyway, if a good scrub of boot polish was good enough for Burt Munro, it's fine with me!! ]
I don't 'know' whether it's worth scrubbing the tyres in storage with something like linseed oil, to help retain/restore some of that suppleness that age, and the drying out of the rubber loses?
BTW, on a hot dry day, a totally bald tyre has better grip than one full of tread....
The sheer cost of crossply tyres these days puts me off looking at pre-war cars......Knowing that the chances are I'd have to replace all 5 or 6? That would cost more than I'm usually prepared to pay to buy a daily driver!
Somehow, getting 'value-for-money' out of such an outlay would prove difficult in my eyes. _________________ Dellow Mk2, 1951 built, reg 1952.
Joined: 16 Oct 2008 Posts: 1164 Location: Upper Swan, Western Australia
Posted: Wed Mar 12, 2025 4:25 am Post subject: |
Personally I won't ever use radial tyres on a car that was never designed to use them. Which covers all prewar cars and most in the early years after the war.
I have driven early Falcons and Holdens that had been fitted with radial tyres in later life and found them to be very dangerous on wet or greasy roads. Both Ford and Holden started fitting radial tyres on their new cars AFTER they had introduced RTS (Radial Tuned Suspension) The whole front end geometry was changed to suit the completely different characteristics of Radial tyres.
My Austin A40 has never worn radials and will never wear them during my ownership. Still on 525/550x16 crossplies. Forget all about softer rides and personal comfort, the only time you know whether your tyres are right is when you have bad road conditions and find yourself in an emergency.
As far as tyres aging goes, with our brutal sun the walls can degrade quite rapidly. I don't think we have actual laws on replacing old tyres, but obviously tyre dealers would like us to change them every year. Now I am retired my daily driver does not spent five days a week in a carpark and my old cars live in a closed garage hidden from the sun and so tyres last far longer than a few years. However, I do regularly check the walls for any sign of cracking.
1950 Austin A40 tourer
1999 BMW Z3
Posted: Wed Mar 12, 2025 10:56 am Post subject: |
Not speaking from personal experience but I have noticed how everyone who has had much experience of the Mark 6 Bentley (introduced in 1946) has said how much better it drives on radials.
It may only be a coincidence but the design was all new with very little in the way of pre War elements. Perhaps the RR designers were aware of tyre developments in the pipeline.? |
Norseman
Posted: Wed Mar 12, 2025 11:06 am Post subject: |
Keith D wrote: |
Keith |
A few months after purchasing my Range Rover classic (a model I was well used to having owned 3 previous examples) I was negotiating a roundabout in heavy rain & felt the car losing traction, something that certainly shouldn't happen on tarmac given the perm. 4WD. Deciding to check dates on the apparently excellent condition Michelin tyres with deep tread depth I found to my horror that they were 22 years old so probably original fitment. I assume the age related hardness of the rubber was causing the loss of traction .. thank God I hadn't needed to do an emergency stop on a wet road. _________________ 1987 classic Range Rover Vogue auto
Posted: Wed Mar 12, 2025 11:21 am Post subject: |
Quote: | Personally I won't ever use radial tyres on a car that was never designed to use them. Which covers all prewar cars and most in the early years after the war. |
I think that covers most mainstream mass produced [cheap?] cars made up until at least the late 1960's, if not into the 1970's?
I recall many mainstream production cars of that time period being sold with crossply tyres, but also being available with radial tyres! [As a selling point?]
In the USA, probably right up until the 1970's, the base models of the popular [cheap] ranges for Fords, etc, came with cross ply tyres as standard.
The problem US tyres had, at that time, was the rubber mix was unsuitable for European roads & climates.
The main issue when comparing cross ply tyres and radials, on the same model, for me, is that the noted tyre pressures bear no relationship to the type of tyre.
I often see folk using crossply tyre pressures for their radial tyres....because that what it said ''in the manuals!''
My Dellow's front wheels,with their cross ply [Avon dingdongs] tyres, have pressures listed as around 14-19 psi, depending on use. [It's not a heavy car]
Yet, even though the intended cross ply rear tyres listed....have pressures noted at around the same figures, having fitted radial [taxi] tyres to the rears, I wouldn't dare run far with those pressures.....the tyres would heat up tremendously. So, after experimentation, I run those rear radials at around 26 psi....going by deflection of the carcass, etc. A good 10 psi above what Dellow suggested for crossplies [5.50/6.00 x 16 being te normal rear tyre size....]
Remember, those tyre pressures may well have been 'written in blood' [iE the manuals] back in the 1950's....? _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Wed Mar 12, 2025 12:22 pm Post subject: |
Keith D wrote: | Both Ford and Holden started fitting radial tyres on their new cars AFTER they had introduced RTS (Radial Tuned Suspension) The whole front end geometry was changed to suit the completely different characteristics of Radial tyres.
Keith | Interesting, certainly BMC changed from x-ply to radials on many models in the 70's , such as the MGB without any suspension changes? |
Rusty
Joined: 10 Feb 2009 Posts: 271 Location: Bunbury, Western Australia
Posted: Thu Mar 13, 2025 1:26 am Post subject: |
ukdave2002 wrote: | Keith D wrote: | Both Ford and Holden started fitting radial tyres on their new cars AFTER they had introduced RTS (Radial Tuned Suspension) The whole front end geometry was changed to suit the completely different characteristics of Radial tyres.
I suggest "Keith" is right about cars designed "before" radials! I have a mate with a Studebaker cruiser fitted with "radials" which I consider has terrible driving characteristics and not because of the steering geometry which has been checked and found to be within manufacturers specs, so I put it down to the tyres. "Studes" would "definitely" never have had radials even as an option having closed the main factory in 1963, and the last Canadien plant in 1966, but other manufacturers during the 70s had both radials and crossplys available on the same models at the same time. A lot of the more budget minded "British Leyland" cars sold out here in the early 70s had the option of both and I remember taking sets of crossply fitted wheels off cars such as Austin 1800s and Leyland P76s and fitting sets of new wheels already mounted with radials because the customer had ordered the upgraded radials, but that didn't seem to affect the handling characteristics of the cars, so I suspect there was something deeper in the design that made them acceptable to both tyre types. |
