Brake bleeding
Goto page 1, 2, 3, 4  Next
Southernscouse
PostPosted: Sat Jun 07, 2025 1:20 pm    Post subject: Brake bleeding Reply with quote
Hi people I need help with my 1954 Devon van tried the vacuum method to bleed the brakes with no success so purchased a pressure system
While the air is connected I have a firm pedal but this fails when the air is off
I have run over a litre of fluid through the system and have no leaks
Is it pointing to a new master cylinder Cheers Tom
PostPosted: Sat Jun 07, 2025 1:29 pm    Post subject: Reply with quote
Will it pump up (with the pedal)?
Southernscouse
PostPosted: Sat Jun 07, 2025 1:37 pm    Post subject: Brake bleeding Reply with quote
It will pump up pressure but only if I do it fast enough will hold pressure if I keep pressing the pedal but if I release pressure is lost
PostPosted: Sat Jun 07, 2025 1:39 pm    Post subject: Reply with quote
Hello SC. I don't think you need a fancy bleeder set up. All I have ever used is a simple rubber tube with the end blanked off and a slit near the end and a clean glass jar half filled with brake fluid. Make sure the master cylinder is full.
Starting with the wheel furthest from the master cylinder, fit the tube on the bleed nipple and the other end in the brake fluid. Crack open the bleed nipple and depress the brake pedal a few of times. When bubbles stop appearing in the jar tighten up the bleed nipple and go onto the next one. Make sure the master cylinder is kept topped up.
You can speed things up with a helper depressing the brake pedal but I usually do it by myself.
Hope this helps.
PostPosted: Sat Jun 07, 2025 2:49 pm    Post subject: Re: Brake bleeding Reply with quote
Sometimes I have found that leaving the car for 24 hours and then re-bleed cures the problem; if there are multiple small pockets of air, it can be problematic to bleed them all out, leaving it for 24 hours and the air will try and get to the highest point in the system, more importantly you have one (or fewer) large air bubble rather than many small, and this then becomes easier to bleed.
I use a Gunson Easybleed (bought in about 1980!) and a tyre with a quite low pressure.
The other thing I'm thinking of, is that I think your master cylinder has a slow return valve, these have been problematic in aftermarket kits, have the MC seals been changed recently?
Southernscouse
PostPosted: Sat Jun 07, 2025 2:50 pm    Post subject: Brake bleeding Reply with quote
Now looking at my own replies I have bad feelings it?s pointing to a new master cylinder anyone have a good one laying around
Southernscouse
PostPosted: Sat Jun 07, 2025 2:51 pm    Post subject: Brake bleeding Reply with quote
Southernscouse
PostPosted: Sat Jun 07, 2025 2:52 pm    Post subject: Brake bleeding Reply with quote
I am thinking I need a new master cylinder
PostPosted: Sat Jun 07, 2025 2:57 pm    Post subject: Re: Brake bleeding Reply with quote
If the M/C will pump up and hold pressure, then I don't think that's your problem, if it holds pressure then both the bore and main seals are good.
Southernscouse
PostPosted: Sat Jun 07, 2025 3:26 pm    Post subject: Brake bleeding Reply with quote
Yes it holds pressure while it is under pressure but fails once released
Southernscouse
PostPosted: Sat Jun 07, 2025 3:29 pm    Post subject: Brake bleeding Reply with quote
I have also tried using an assistant and also used a tube with a one way valve
Southernscouse
PostPosted: Sat Jun 07, 2025 3:37 pm    Post subject: Brake bleeding Reply with quote
Reply for uk Dave
Can tell what a slow return valve looks like
It?s a1954 Devon van
Southernscouse
PostPosted: Sat Jun 07, 2025 3:58 pm    Post subject: Brake bleeding Reply with quote
Reply for uk Dave
This slow return valve is it also called the recuperating seal
Before I spend big money I will get a seal kit and see what happens
Rusty
PostPosted: Sun Jun 08, 2025 2:16 am    Post subject: Reply with quote
To diagnose it ,one would really have to feel it oneself, but if the fluid coming out is "air free" on all bleed points that could be a primary bucket worn. Sometimes they will hold pressure when pumping but let it off when pedal pressure decreases such as you are describing, and won't leak fluid through the secondary bucket out to atmosphere. Would need a new kit through the cylinder to fix it, but before you do that check for any other culprit, like ,maybe a brake light switch in a high position trapping air (I have seen it), or does it have a non standard fitting such as a booster that could need bleeding.
Southernscouse
PostPosted: Sun Jun 08, 2025 11:42 am    Post subject: Brake bleeding Reply with quote
The master cylinder is mounted on the chassis with the brake light switch on the end the reservoir is high on the bulkhead all standard no brake boost
Page 1 of 4
