consul 57
Posted: Wed Jun 25, 2025 11:15 am Post subject: |
| Penman wrote: | | I don't know if the CBT and road bike courses use manual or auto. But I know that when the Japanese bikes first came over here they had the Footbrake and Gear Change pedals on opposite sides compared with the British bikes. |
very few auto bikes about, mostly scooters and mopeds/cubs ect.
yes the jap bikes had the gear & brake opposite, but i think all bikes now have the same set up.
my mate had an early bultaco trials bike and had to sell it as it had the british way round for the brake & gear and he was so used to his other bikes being the other way round he had to sell it as he would quite often come to a stop whilst trying to change gear! |
bjacko
Joined: 28 Oct 2013 Posts: 573 Location: Melbourne Australia
Posted: Thu Jun 26, 2025 7:23 am Post subject: Motor Cycle Licence tests |
I put a Vincent Firefly 48cc motor on my bicycle and took my test at Macclesfield when I reached my 16th birthday. I passed and it enabled me to ride any type or size vehicle classed as a motor cycle!! _________________ 1938 Morris 8 Ser II Coupe Utility (Pickup)
1985 Rover SD1 VDP |
norustplease
Posted: Wed Jul 02, 2025 9:01 am Post subject: |
Just as a matter of interest, can you drive a motorcycle combination on a car licence? (Motor bike and sidecar , that is.) _________________ 1953 Citroen Traction
1964 Volvo PV544
1973 VW Beetle 1303L
Boring Suzuki SX Hybrid |
Joined: 23 Nov 2007 Posts: 4360 Location: South Cheshire
Posted: Wed Jul 02, 2025 10:45 am Post subject: |
If you have Cat A on your licence with a 79(3) restriction, which you should have if the car test was past prior to the late 90's, this is the entitlement:
A driving licence code 79(3) in category A (motorcycles) means the holder is restricted to tricycles only, meaning they can only operate three-wheeled motorcycles. It does not specify a speed or weight limit for the tricycles. The code effectively limits the holder to tricycles and excludes them from operating two-wheeled motorcycles or other vehicles within the motorcycle category.
Key points about code 79(3) on a UK driving licence:
Restricted to tricycles:
The holder can only drive three-wheeled motorcycles.
No speed or weight limit:
The code does not specify any restrictions on the speed or weight of the tricycles the holder can operate.
However I think adding a side car doesn't make a bike a 3 wheeled vehicle, so no.
Category A:
The code is associated with the motorcycle category (A) on the driving license.
Excludes other motorcycles:
It effectively excludes the holder from operating two-wheeled motorcycles or other vehicles within the broader category A. |
Posted: Wed Jul 02, 2025 1:21 pm Post subject: |
Many moons ago a car Licence was Group A and I believe M/Bikes were Group B at that time. Then harmonisation of licences with Europe took place so the change over to Categories happened
A car licence is Category B. But just as with Category A you can drive a trike. You cannot drive/ride a combination on a Cat B car licence
You can check all categories here:- https://www.gov.uk/driving-licence-categories.
I found absolutely no mention of m/cycle/sidecar combinations on that page using the Ctrl F search function.
Before they started messing with many different types of M/cycle tests, probably when it was still groups, there was a provision that you could learn on a larger cc bike provided it had a sidecar, but you could only carry a full licence holder as a passenger, just like the rules they had for pillions.
A m/cycle training company has posted:-
"A License
Eligibility: Available to riders aged 24 and above (direct access) or 21 and above (progressive access).
What You Can Ride: Unrestricted motorcycles in size and power, with or without a sidecar, and motor tricycles with power output over 15 kW.
Requirements: Direct access route (CBT, theory test, practical test) or progressive access route (2 years experience on an A2 motorcycle and a further practical test)."
It is a British company so I don't know why it isn't using the English spelling of Licence _________________ Bristols should always come in pairs.
Joined: 14 Oct 2016 Posts: 2226 Location: East Yorkshire
Posted: Wed Jul 02, 2025 1:55 pm Post subject: |
| Quote: | | It is a British company so I don't know why it isn't using the English spelling of Licence |
Google won't let them....?
Now, what about 'quad' bikes?
Interestingly [or not?], the Hagglunds BV... a 'tracked,' doubled-up pair of boxes with huge overland [& water] abilities....requires nought but a C1 licence [or even, a Cat B, I cannot recall exactly]...Rather than a 'tracked' licence....Owing to the fact it is a 'skid steer,' push me pull -you' vehicle, rather than one that brakes individual tracks to steer.
Much like the big Volvo off road tipper thing...4 wheels, two bodies, joined by a rotary joint to steer...Only with a tracked wheelset, rather than one round wheel, on each corner.
Today's front garden view from my home elicited a tractor with a similar tracked setup....
Which will annoy all those who have gone to the trouble of passing their 'tracked' vehicle test. _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Wed Jul 02, 2025 6:15 pm Post subject: |
alastairq: I can remember when I first started instructing examiners would sometimes have to go out to do tests for "other categories vehicles".
The "f" Agricultural tractor was the most common because it got the 16yr old farm lads legal ASAP. (There was an argument later on, after the +E Cat came in, when FastTrax came out that 16yr olds could be towing a trailer legally on a motorway.
The "k" pedestrian controlled was still being used for the walking. tiller controlled, electric milk floats and "l" was for the sit in and drive milk floats. I think "M" trolley vehicles had all been withdrawn from service by then and I suspect that when they were in use the bus companies had delegated examiners anyway. Nowadays trolley vehicles are at places like Sandtoft and I don't know what licences are needed for them, presumably similar to those needed for other preserved buses and tramways.
"n" is an interesting one because motability is exempt from duty (if that means Road Tax) but they have to pass Cat B. _________________ Bristols should always come in pairs.
V8 Nutter
Posted: Fri Jul 11, 2025 9:12 am Post subject: |
| My club, American Auto Club UK is very lucky as far as members age is concerned, we have plenty of older members. I think the oldest is 94 and still driving, but most of the committee are in their 50's and we have many members in their 30's and 40's. Our youngest active local member is 25, he is on his second American car a 1971 Dodge Challenger. I think all the re-runs of old movies from the 50's,60's and 70's helps to keep the interest going, plus it is usually so easy to obtain parts, even for old cars going back as far as the 1920's. The shipping can get a bit expensive, but several companies do containerised shipping which saves a fortune, if you are not in a hurry. The last parts I bought for my 1970 Cadillac was most of the exhaust system. I had a choice a spurious one or for a few dollars more one made to original specs. Even with shipping the price was comparable with a big British or European car, and it arrived in three days. |
Posted: Fri Jul 11, 2025 10:44 am Post subject: |
| Quote: | | Even with shipping the price was comparable with a big British or European car, and it arrived in three days. |
I was a Rock Auto regular ....and found their prices, including Fedex, to be probably cheaper than similar types of spares for commonplace UK cars.
Never mind for a 67 US Ford!
Plus, the US cars were so much easier to work on.....Far less cramped.
No longer have that car.....pension-drought. _________________ Dellow Mk2, 1951 built, reg 1952.
