Joined: 23 Nov 2007 Posts: 4240 Location: South Cheshire
Posted: Thu Jul 10, 2025 4:00 pm Post subject: |
alastairq wrote: | Sometimes....the actual position of the bleed screw also affects the ability to expel any air.
Particularly concerning certain clutch slave cylinders....where the bleeder gets positioned , not exactly at the 'highest ' point. | MGA/B's clutch slaves are like that! |
Joined: 14 Oct 2016 Posts: 2121 Location: East Yorkshire
Posted: Thu Jul 10, 2025 4:56 pm Post subject: |
ukdave2002 wrote: | MGA/B's clutch slaves are like that! |
Thanks...I suspected I wasn't going gaga!
I wondered if there was a screw-in replacement for the bleeder on the slave, leading to a pipe with led to another bleeder located higher up in the engine bay ? {Easier to get at without the crawling under process?] _________________ Dellow Mk2, 1951 built, reg 1952.
Joined: 23 Nov 2007 Posts: 4863 Location: Swindon, Wilts.
Posted: Thu Jul 10, 2025 7:32 pm Post subject: |
I remember having a Renault which had to have a bleed valve at the highest point on the heater hose run because it was way above the filler cap, expansion tank and even the top of the radiator. _________________ Bristols should always come in pairs.
Rusty
Joined: 10 Feb 2009 Posts: 278 Location: Bunbury, Western Australia
Posted: Fri Jul 11, 2025 2:44 am Post subject: |
We had a model of locally assembled Dodges out here circa about 1960 that had brakes notorious for being impossible to bleed, and the reason ended up being an air trap under the brake light pressure switch which was mounted on top of the fluid line and under the floor. Once the problem was found out about, all you had to do was get someone to hold the pedal down and crack the switch until the air came out and all was fine. |
Southernscouse
Joined: 30 May 2024 Posts: 26 Location: Havant Hampshire
Posted: Mon Jul 28, 2025 5:09 pm Post subject: Brake bleeding |
At last success I have brakes adjusted all brakes so they were fully on bled the system yet again had so pedal pressure at last while I was at it noticed that the front brakes were near the limit of the adjustment so replaced the brake linings pedal position was better and pedal was firm thanks to everyone with comments and ideas problem now solved
L |
