MG TC
Goto page Previous  1, 2, 3 ... 88, 89, 90, 91  Next
100%
 100%  [ 7 ]
0%
 0%  [ 0 ]
Total Votes : 7
PostPosted: Sat Nov 08, 2025 10:54 pm    Post subject: Reply with quote
A further update today. The oil pressure warning light was actually leaking from the flexible hose; not the union as I had first thought. This means I have been sold yet another faulty new part which will need to be replaced.
The question of the brakes not working is getting beyond my pay grade. The master cylinder and wheel cylinders are all new as is the pipework. The 1.9:1 servo is a genuine Lockheed unit (not one of the super cheapo Chinese copies that are flooding the market) and I have installed everything as best I know how using the correct hose.
If the engine stumbles badly when I apply the brakes, I assume the air being drawn from the servo is interfering with the mixture.???
I may be forced to add an electric vacuum pump; thus removing the engine from the equation.
PostPosted: Sun Nov 09, 2025 8:52 am    Post subject: Reply with quote
Are there any valves in the servo air circuit that could either be faulty or fitted the wrong way round?
PostPosted: Sun Nov 09, 2025 10:19 am    Post subject: Reply with quote
Good question. The only valve in the system is the check valve that is attached to the servo unit. I have not added any other valves ...although I probably should do.
I would much prefer to use the engine vacuum if I can rather than fit an auxiliary one. I was advised by Steve Baker (s/c supplier) to take it from the supercharger end plate; that is after the carb and before the impellers. My friend and neighbour has suggested I try fitting a restrictor in the line.
The problem I have at the moment is that I can't have the engine running because of the oil leak from the flexible hose. I took it off but have no means of capping the union. I have ordered a new hose on line.
PostPosted: Fri Nov 14, 2025 12:25 pm    Post subject: Reply with quote
So... I received the hose but unfortunately it has metric threads... when what I needed was BSP. This is what happens when you try to save a few quid. The stainless steel braided hose was advertised as 1/8" which (being an imperial size) led me to assume it was 1/8" BSP. The diameter of the female couplings was the right size for BSP but it has metric threads so will not fit.
In the end I have bought the right part from Octagon Car Club spares...which is what I should have done in the first place.
Will I ever learn?
PostPosted: Sat Nov 15, 2025 1:22 pm    Post subject: Reply with quote
Just to add even more angst to this job, the new oil hose from Octagon - while the correct 1/8" BSP fitting - is a fraction too long for the union fitting. As can be seen the nuts (at both ends) on the replacement are longer and presumably will need to be pared back.
It is cold and wet and I am not in the right frame of mind for mucking about... so I have shut the garage door on it.
PostPosted: Sat Nov 15, 2025 6:26 pm    Post subject: Reply with quote
I have now ground down the nuts and fitted the hose. No more oil leaks, thank goodness!
I checked the servo by pressing the pedal and starting the car. If the servo was working correctly the pedal would have dropped an inch or so when the engine fired ... but there was hardly any movement at all. If I start the engine then depress the pedal it will immediately stall.
PostPosted: Sat Nov 15, 2025 6:27 pm    Post subject: Reply with quote
PostPosted: Mon Nov 17, 2025 7:16 pm    Post subject: Reply with quote
It looks like there is insufficient vacuum to operate the servo. Not only is this because I have a supercharger but I have discovered that my new sports camshaft has greater valve overlap which leaves less time for a vacuum to form.
I have decided to order a vacuum pump and do what I can to quieten it down. Ideally I would have chosen a 'vane' type over the 'piston' version because they are much quieter. (60% less).. but they all seem to be made in America and I need to keep things local. The vane pumps are also without exception described as 'plug and go' and 'vehicle specific'; this means if I cut off the pre wired plugs for my installation ...and there is a problem ... I will not be able to return the pump for a refund.
This video shows the set up of a simple vacuum pump - up as supplied by 'Car Builder Solutions' - so all I need to work out is how best to mount it in the car. I plan on fitting the pump in the enclosed area behind the seat; opposite the servo. I have also ordered a small K&N filter which should help reduce it's noise.
https://www.carbuilder.com/products/electric-vacuum-pump?variant=41978131120182#video-gallery
PostPosted: Mon Nov 17, 2025 8:43 pm    Post subject: Reply with quote
Make up an adaptor cable for the pump so you can keep the original pump connections for guarantee purposes, but plug them into the car's loom via the adaptor you've made up?
PostPosted: Mon Nov 17, 2025 10:12 pm    Post subject: Reply with quote
Do you really require a brake servo? It seems like a lot of hassle?
PostPosted: Mon Nov 17, 2025 10:38 pm    Post subject: Reply with quote
Sorry Alastair I should have been clearer. The pump I have ordered is the one from 'Car Builder Solutions' and should be with me in the next day or so. This is a simple kit and does not have any plugs to worry about.
I would have preferred a quiet vane type pump but I have been unable to find a U.K. supplier who can offer it at a sensible price; so rather than risk buying from the U.S.A. I have settled for a piston type from Car Builder Solutions. If I have a problem I can easily phone them or return it without any hassle.
I need to remove the vacuum hose from the supercharger end plate and plug the holes.
To that end I have ordered some 1/8" BSP end plugs
PostPosted: Tue Nov 18, 2025 12:35 am    Post subject: Reply with quote
It is now five years since I installed the brake servo but it has taken this long to get to the point of testing it; only to find that my engine will not develop enough vacuum. This has been a significant disappointment to me, especially as I had been advised by someone - who I trusted - to move the take off point from the inlet manifold to the end plate of the supercharger (between the carb and the impellers) which, as it turns out, is also unworkable.
Many so called 'purists' recoil at the idea of modifying a TC, so installing a brake servo will really annoy some of them. That is just too bad ! I have always aimed at making this car as usable as possible because in reality a standard TC is pretty lamentable in today's traffic. To that end I have renewed the entire braking system with high quality components including Alfin drums ...and shoes specially developed by Peter Edney.
I am also proud of my remote brake fluid reservoir which makes checking the level and bleeding the brakes so much easier.
TC brakes are actually not that bad... but their archaic design means that they require a lot of effort! Later cars had twin leading shoes which was an improvement but to convert a TC would mean irreversible mutilation of the back plates. (There was a popular conversion using Marina van back plates but these are no longer available.). It has always been my philosophy that any changes I make to the car should be easily reversible so I have opted to work with the design rather than permanently change it... and the addition of a servo is part of that ethos.
I am aware that a servo will do no more than assist pedal pressure but I am happy that getting it to work will be worth the trouble. It means that longer journeys should not result in as much back and leg ache and the driving experience generally should be improved.
Regardless of any improvement that may result from fitting a servo (however the vacuum is achieved) a great deal of time and money has been invested and it would be a shame not to make the most of it.
bjacko
PostPosted: Tue Nov 18, 2025 7:04 am    Post subject: Adding A Servo To The Brakes Reply with quote
My Morris 8 has similar brakes to the MG's and I find they are pretty good. The way we drive our old cars there is not a lot of usage for the brakes but when you need them they work fine. I find driving with as little brake usage as possible not only saves wear and tear on the brakes it also saves fuel. I learnt during the Suez crisis when we had rationing of fuel in UK.
Of course we are used to our modern cars with servos etc but you cannot compare the two, although some people do and complain about old car brakes.
Whilst I was restoring my 8 I had a 1927 Cowley and they were not the best brakes but you learn to cope with them and make allowances and watch for idiots cutting in on you. Never had any leg aches because they are not used as much, as old cars do not have the acceleration of modern cars.
1985 Rover SD1 VDP
PostPosted: Tue Nov 18, 2025 10:53 am    Post subject: Reply with quote
I must stress that I am not saying that there is a problem with the brakes. I am now in my 70s and the need for a gentler pedal has more to do with me than the car. When I was younger I wouldn't have bothered but as I get older I will still want to enjoy driving it. The same reasoning is behind a steering upgrade. Importantly, I am not alone as all of my mods have been done many times before.
I liken driving an old car to riding a traditional British motorbike. The salerooms are packed with wonderful old bikes which have just become too heavy for their elderly owners.
PostPosted: Wed Nov 19, 2025 6:57 pm    Post subject: Reply with quote
The electric vacuum pump arrived this morning from Car Builder Solutions. It certainly looks good and fitting should be straight forward. A small air filter has been included (which I can fit to the pump exhaust to help reduce noise).
Despite the cold, I ventured out to the garage and started the fitting.
I had previously removed the hose from the supercharger but getting it out of the chassis rail was not easy; even one of the clips in the chassis had to be ground off.!
Eventually I was able to pull the hose out and start thinking about where to cut it. Luckily the pump will sit neatly on the chassis rail on the opposite side to the servo. It's bracket is mounted on four rubber feet - 40mm apart - which means they can neatly straddle the chassis rail. The feet have 3/16" studs that need to be fixed to a firm surface.
To ensure a secure fitting I measured and drilled four holes in a piece of steel plate and attached the feet to the the pump and the plate with the supplied nuts but added spring washers for extra security.
To secure the assembly to the chassis rail without drilling holes in it, I will be fitting two 40mm x 110mm 'square' U bolts. I did this successfully with the servo (on the opposite chassis rail).
I will need to drill four 10mm holes in the steel plate to accept the U bolt threads but when fitted to the chassis it should be perfectly sound.
To help the pump blend with the chassis and axle I shall paint the steel plate gloss black.
Another part that will require fitting is the switch. This has two ports and an electric connection point. It needs to be mounted between the pump and the servo. Conveniently, an existing thread provides a central location.
The electrical supply - which includes a dedicated relay - will need thinking about because it wants to be ignition activated. I had hoped to have finished the electrics but ...such is life.
Page 89 of 91
