Goto page Previous  1, 2, 3 ... 142, 143, 144
PostPosted: Sun Nov 16, 2025 7:41 pm    Post subject: Reply with quote
Spent yesterday morning working on our 1944 Commer. We're still trying to remove the engine, she's seized in place but after a few weekends of soaking everything we can we have finally got some movement. Another go at it next weekend should have the engine out so we can start it's rebuild over the winter.
PostPosted: Mon Nov 24, 2025 10:09 am    Post subject: Reply with quote
Well, all I can say is the Commer designers didn't make it at all easy. Everything is ready to go now, all freed off and we have movement!! But still we can't remove the engine, we cant lift the back end at all due to the cab floor! I've gone back to my manuals and finally found one that actually refers to engine removal...it says:
"To permit sufficient clearance to be obtained between clutch housing and the cab proceed as follows:-
(a) Release the nuts that secure the three cab silentbloc mountings (one at the rear and one either side) to brackets on the chassis frame.
(b) With jacks on either side, raise the cab 1 in. to 1 1/2 in. Do not exceed this amount, otherwise the front mounting will be subjected to excessive strain."
So now we have to lift the whole cab off!!
PostPosted: Mon Nov 24, 2025 6:39 pm    Post subject: Reply with quote
Replaced the coolant in the Firenza yesterday as I'll need to use it at the end of the week. It's a bit difficult to drain properly, so I just undid the bottom radiator hose, let it run, then put it back. I then stuck 2l of anti-freeze in (as per the manual for 25% strength) and topped it up with water, then ran the engine for a bit. I should have driven the car around, but it was a bit too wet for that.
PostPosted: Fri Nov 28, 2025 6:10 pm    Post subject: Reply with quote
Dunno where else to put this...but for those whose cars a really, truly, jammed up........
https://www.youtube.com/watch?v=8ukpVWtQBNc
PostPosted: Fri Nov 28, 2025 6:41 pm    Post subject: Reply with quote
I looked into doing that with my Range Rover with the same problem. It wasn't possible because they need to get to one end of the vehicle or the other. Only the side was available. I arranged for a recovery vehicle to remove it but they took one look and went away.
You will remember I found a fuse in N0.11 that shouldn't have been there. I removed the fuse and solved the problem. Phew!
PostPosted: Fri Nov 28, 2025 7:49 pm    Post subject: Reply with quote
Thanks Ray..I knew your posts were somewhere....
PostPosted: Mon Dec 01, 2025 10:08 am    Post subject: Reply with quote
Finally, we have the engine out of our Commer.
In the end I had to cut the head off one of the engine mounting studs but I can replace that. Even with clearance it still too quite a bit of work to free her from the splines but after so many weekends of trying we were all pretty pleased.
Now the seized engine is in the shed, in the dry, we can start the full strip down and rebuild over the winter months.
PostPosted: Mon Dec 01, 2025 10:11 am    Post subject: Reply with quote
I've started the alterations to my overdrive gearbox to hopefully fit it in a car this winter. It's come from a different model where the gear lever is further forward, so it has to come backwards. I was kindly given some photos of how to do it, but they're photos of printouts of photos and not great quality. I've a bit more space to work in now the Sunbeam Alpine project has gone, so at least that's a bit easier.
Page 144 of 144
