Change Brake Master Cylinder
Morris8_2020
PostPosted: Sun Feb 15, 2026 4:58 pm    Post subject: Change Brake Master Cylinder Reply with quote
Hi all
I am looking to change brake master cylinder on a morris 8 ser 1 has anyone done this before 7/8? bore.
PostPosted: Sun Feb 15, 2026 5:33 pm    Post subject: Reply with quote
Yep it?s 7/8? seals are available from the Morris Register, you will need a 5/8? BSF tubular box spanner to remove and refit the cylinder.
bjacko
PostPosted: Mon Feb 16, 2026 7:50 am    Post subject: Remove Morris 8 Master Cylinder Reply with quote
You can also do it with an open ended spanner. Do not loose the thin brass washers at the Tee piece when you remove the special BSF threaded bolt.
The washers are two different sizes too.
1985 Rover SD1 VDP
