Les Foster
Posted: Fri Jan 25, 2008 6:34 am Post subject: E83W Passenger seat |
Yes, I agree that I think it would be basically the same as the driver's seat except it would need a higher mount. The Estate Car uses a seat that is the same style as the driver's seat but has longer legs to make it easier to sit in with no footwell. I imagine the passenger seat for the pickup would be similar but not quite as high as you must sit closer to the windscreen due to the tiny cab. Interestingly, I recently placed some pickup driver's seats beside van driver's seats and the pickup ones are smaller. They look the same at a glance but when directly compared the cushion area is shorter to fit the cramped space. They also do not slide on tracks as there is no place to go! They simply tilt up to acess the tool boxes or on LHD models, the battery. |
