Joined: 23 Nov 2007 Posts: 4401 Location: South Cheshire
Posted: Thu Jul 09, 2026 11:38 am Post subject: |
If its a Ray described; CPU operates a relay directly, it would be easy to add or try a remote pump, if its on a CAN it may be more tricky as there may be some acknowledgement required from the pump module.
Given the age of the car its probably the former. |
Posted: Thu Jul 09, 2026 12:18 pm Post subject: |
| ukdave2002 wrote: | If its a Ray described; CPU operates a relay directly, it would be easy to add or try a remote pump, if its on a CAN it may be more tricky as there may be some acknowledgement required from the pump module.
These cars do have a CAN but at this point in time the fuel pump had not yet been integrated.
I have been mulling this over and in my clumsy way what I am trying to say is that the ECU doesn't know one pump from another... so if the wires that go to the old pump are sent to the new 'in line' one it should be O.K.
(Famous last words of course)
Joined: 14 Oct 2016 Posts: 2240 Location: East Yorkshire
Posted: Thu Jul 09, 2026 3:59 pm Post subject: |
One could always disconnect, if reachable, the wires from the in tank pump connections, plug them into a suitable clacky electric high pressure pump, and see if it clacks with ignition turned on? _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Thu Jul 09, 2026 4:36 pm Post subject: |
| alastairq wrote: | | One could always disconnect, if reachable, the wires from the in tank pump connections, plug them into a suitable clacky electric high pressure pump, and see if it clacks with ignition turned on? |
I am sure you are right. I don't see why it would not work. One might even regard it as an improvement!
I should have done that when my Range Rover petrol pump failed but it would have involved spoiling the fitted interior. In the end I just let a Land Rover specialist replace the pump from underneath. It needed a lift to raise the car high enough off the ground to allow the tank to drop down so the pump could be extracted from it. |
Posted: Thu Jul 09, 2026 5:01 pm Post subject: |
| I'd first check the relay, including is there a demand on it (which I'm sure Rick will have already done), if its working, pop it out, quirt 12v down the relay output and see if its drawing any current, if yes and there is no fuel pressure then it looks as if the pump has a mechanical fault, if no current draw then we either have a faulty connection or electrical fault with the pump. Narrowing it down is how to solve electrical faults. |
Joined: 30 Apr 2013 Posts: 4300 Location: The Somerset Levels
Posted: Tue Jul 28, 2026 12:41 pm Post subject: |
I quite like the late 30's Morris 12. A chap we always used to see at our local show had one. Very nice cars. _________________ Various Rootes Vehicles. |
