Joined: 23 Nov 2007 Posts: 4266 Location: South Cheshire
Posted: Wed Jan 30, 2008 8:35 pm Post subject: Couple of old garage workshop tools |
Bit of a quiz
I do like old tools and have kind of ended up collecting them, here is a couple of tools that would have been in most garage workshops, from just after the war and through to the end of the 60's, can you ID them? the first one is made by Crypton and you can probably read enough to figure out what it is for, the 2nd is made by Pickavant .
poodge
Posted: Sat Feb 02, 2008 6:44 am Post subject: |
Does the Crypton analyzer analyze Kryptonite(Superman)?
Something about commutator can be read,so perhaps to test dynamo/starter motor.
The second one looks like a bearing press,or perhaps something to do with clutch work. |
Posted: Sat Feb 02, 2008 12:09 pm Post subject: |
I think the key word on the Kryptonite tester is "Growler"!.
Now what does a growler do?
I thought the second one looked clutchish too, but I can't really think what it does.
I've another one to add to this game. I'm away from home for a few weeks and thus I don't have the object to photograph so here's bad sketch of it.
The part nearest is a grease nipple and the jaws of the clamp have blunt chissel like blades.
Posted: Sat Feb 02, 2008 1:40 pm Post subject: |
Looks a bit like some sort of nut-splitter (ouch) How big is it?.
Don. |
Posted: Sat Feb 02, 2008 1:50 pm Post subject: |
I would guess there is between about 1" to 3" between the jaws depending on how it's adjusted.
I have found it to be quite a useful tool. It's not a nut splitter.
Peter |
Posted: Sat Feb 02, 2008 2:55 pm Post subject: |
Of course, It's a spring lubricator  |
Posted: Sat Feb 02, 2008 9:58 pm Post subject: |
Gosh! Maybe my drawing skills are better than I thought.
But what about that clutch thingy? |
Posted: Sun Feb 03, 2008 1:36 pm Post subject: |
Peter spot on with the 1st tool as you say it is a "Growler" used for finding faults in armatures, in the days when a garage would both test and repair armatures rather than replacing the whole unit!
The 2nd one Peter & Poodge are on the right track, its a "Dummy Flywheel Clutch Tool" used for setting the release levers on older clutch's; to ensure that the clutch plate is parrallel to the flywheel face.
Here it is with a clutch in;
And one of the 3 levers you need to adjust;
Uncle Joe Guest
Posted: Tue Feb 05, 2008 1:00 pm Post subject: |
Continuing this topic a little, this is an exact copy of a factory tool that I made 30 years ago this year. But I wonder if anyone knows what it is used for?
Job-Rated
Posted: Tue Feb 05, 2008 1:01 pm Post subject: |
Is it for hitting Traffic Wardens?  _________________ Don't run your fingers over my truck & I won't run my truck over your fingers!
Uncle Joe Guest
Posted: Tue Feb 05, 2008 1:05 pm Post subject: |
Dont want to damage a tool that is so old....  |
Posted: Tue Feb 05, 2008 7:41 pm Post subject: |
| Is it for locking something during dismantling or assembly? |
Uncle Joe Guest
Posted: Tue Feb 05, 2008 8:01 pm Post subject: |
| This may confuse, but its used for both dismantling and assembly, in exactly the same way.... |
