Posted: Mon Mar 31, 2008 6:51 pm Post subject: |
Well, decided to take the battery off today, ready to give it a good charge, it was all furry again!
Had a good look and all round the top it has cracked. Only a year or two old aswell!
I think I will go for a normal 6V battery this time, hard rubber seems to be not up to it, and damn expensive to buy!
Posted: Tue Apr 01, 2008 8:29 pm Post subject: |
Well what a cuffuffle!!!
I got a new battery, had to be a hard rubber number, 112 Amp hrs, so got some oomph!! Nearly £100 though, so I went to try it out, the damn thing is too wide to go in the battery tray!!
Couldn't take it back as it has now been filled with acid, and they are stored dry when new!!
So be damned if I am not using it, I decided to modify the tray! Cut it ans welded it up, needs smoothing off, but seems to fit nicely, just clears the bonnet when closed. Put the bracket on to hold it down, and the damn bonnet foulds on it! Blimin heck I am starting to get angry now!! I then had to modify my bracket and crank the bolt, seems to work, and the bonnet will close but think I will have to rethink it and tidy things up eventually, maybe even buy a smaller battery!
Anyway, I think it will work now so that is good!
Posted: Tue Apr 01, 2008 9:17 pm Post subject: |
112 amps will give you plenty cranking power Dave.
Shame you never tried it before filling it up though _________________ ROVER
One of Britain's Fine Cars |
Posted: Tue Apr 01, 2008 9:32 pm Post subject: |
I should have done really but as it was only an inch bigger than my old one, and there was about 1/2" gap on either side of the old one, I thought it would fit, but was about 1/4" out in my thinking!
I was also had the option of this one or 60AHRS or a lengthy wait, as batteries are becoming harder to get, especially hard rubber 6 volt ones, due to an extreme shortage or lead.
Where is best to take old batteries for scrap value, the batter shop offered me £2.50 for each old one, but then again, how much would the scrappers offer me!
Rich5ltr
Joined: 28 Mar 2008 Posts: 681 Location: Hampshire, UK
Posted: Wed Apr 02, 2008 10:23 am Post subject: |
47p2 wrote: | 112 amps will give you plenty cranking power Dave.
| So... in a 6v battery is 112 Amps the equiavent of a 66 Amp 12v battery? Still pretty chunky though. |
Posted: Wed Jun 18, 2008 11:24 am Post subject: |
Just saw this thread and was reminded about this horrible problem of neutralising spilt battery acid.
In the past I've never been very successful especially where it has got into metal seams but recently I discovered that thick Domestos works well as it leaves plenty of alkaline material nicely stuck there.
Peter |
