Posted: Sun Apr 13, 2008 2:55 pm Post subject: |
Interesting that you should say that, wet sanding was the way I did things for years, then I was told by a paint manufacturer about primer being porous, and that it was not recommended.
Same thing goes for tinting the primer as well. I used to do the same, then the same mfg. told me that tinting was a no-no...
Funny thing is, the only paint that I have ever had trouble with is the one that they sold....
Greeney, what kind of gun do you use? Conventional or HVLP?
This is where we start getting technical....  |
Greeney in France
Posted: Sun Apr 13, 2008 3:03 pm Post subject: |
Why not just go the 2k route, a mask can be purchased for about 60€ admittedly not air fed but absolutely fine as long as it has 2k markings on the filters, I have both types, I use the air fed one for full resprays and the normal one just for the odd part!
As long as you not doing it consistently every day it should not be a problem _________________ www.OldFrenchCars.com
