Greeney in France
Posted: Mon Apr 14, 2008 7:39 pm Post subject: |
There are some flashy products on the market including the likes of POR 15 but I have found hammerite (well the smooth version) perfectly adequate, I have parts on my Jag I painted 10 yrs ago still look as good as they did on the day
I think sometimes its very easy to over think restorations sometimes the simple answers are the best  _________________ www.OldFrenchCars.com
Old-Nail
Posted: Mon Apr 14, 2008 9:39 pm Post subject: |
I've actually been looking at POR15 Greeney I do think it worth the extra money, but again I wouldn't know if it covered galvanised steel without the preparation mentioned by the other fella's.
I may do the underbody panels in that though, with waxoyl on top, no such thing as belt and braces where 2cv's are concerned!  |
Greeney in France
Posted: Mon Apr 14, 2008 9:59 pm Post subject: |
I don't have a galvanised chassis as I have the original rust free one.
I have used por15 which I purchased from Frost. You will still need the special primer its called "metal ready" and it is just a blue watery liquid for galvanised steel and other metals like SS or Aluminum _________________ www.OldFrenchCars.com
Posted: Tue Apr 15, 2008 3:28 pm Post subject: |
O-N, if you are going to use some kind of rust preventative paint for the underside, try looking at a product called Epoxy Mastic....I can give you a link if you want, though it has been posted on here a time or two. |
Old-Nail
Posted: Tue Apr 15, 2008 5:45 pm Post subject: |
Go on then UJ I'll take a look. |
Posted: Tue Apr 15, 2008 5:49 pm Post subject: |
The link is:
www.rust.co.uk
This is the stuff I will be using on my Lincoln. dont know if that is a recommendation though.  |
Old-Nail
Posted: Tue Apr 15, 2008 6:14 pm Post subject: |
Thanks UJ I'll go for that epoxy 321 stuff then, do you brush apply it? |
Posted: Tue Apr 15, 2008 6:28 pm Post subject: |
It can be applied by using either an airless spray, a round brush, or a foam roller. If the surface is poor (rust pitted) then a brush is the best way to go for the first coat. The roller will give the best finish.
Its available in 5 different colours, so it may be possible to colour co-ordinate your underbody....no comments please!  |
