Autoglym
PostPosted: Sat May 03, 2008 12:33 pm    Post subject: Reply with quote
ianm wrote:
Penman, the gtechig sure looks good , any idea of what it costs
Ian
The owner has posted this in response to a similar query.
Quote:
Their price list starts at £650 for a large car, to include the polish
and coating. They charged me more as I needed some sanding, they
repainted my fuel cap, removed a couple of dings, I think around £800.
Their blurb says they can remove scratches as long as they have not
gone through to the base coat. They are next to a body shop and they
matched up my paint to paint the fuel cap so could touch up scratches
It's not cheap but if you have something really special to be finished/re-finished, it may well be worth it to you.
ianm
PostPosted: Sat May 03, 2008 1:09 pm    Post subject: Reply with quote
Thanks Penman, may be costly in the first place but if protects your investment it worth it. By the pics its well worth it.
Ian
PostPosted: Sat May 03, 2008 6:11 pm    Post subject: Reply with quote
Car polished ready for the show tomorrow.
I used one of Meguliars polishes, I was given it a couple of years ago and thought I would try it out.......
Easy on and easy off, leaves a slight powder residue if it is on too thick.
One tip for anyone polishing their car. Use microfibre cloths, they are much kinder to the paintwork and don't scratch plus they are easier to use.
I usually cut one into 4 pieces and use that for applying the polish, a second cloth for removing polish and a third cloth to buff up for a final finish
ROVER
One of Britain's Fine Cars
Job-Rated
PostPosted: Sat May 03, 2008 8:56 pm    Post subject: Reply with quote
Clay bar is a Godsend.
Here's how to use it by my friend Kev...
There are various grades of clay so it is best to purchase the correct one to prevent marring of the paintwork. Usually the major wax manufacturers sell a mild clay which is the best to use.
To see whether your cars' paintwork needs claying (and if you have never done it, then I would guess it does), you will need to get a thin piece of cellophane such as a cigarette wrapper or similar. Gently rub the cellophane along the bodywork of the car. It should feel smooth. If it feels like sandpaper or slightly coarse, then its time to clay bar your car.
As mentioned, most wax companies sell a claybar kit. This should come with a Quick Detailing spray which is used to lubricate the surface allowing the clay to glide across the paints surface and pull the contaminants out.
The paint surface has many undulations caused by bonded contaminants. These are things such as bird lime, tar spots etc. These are left behind after the washing process. The bonded contaminants sit on the surface and will not be removed during the washing process. When light hits the surface, the way it bounces off gives it the depth of reflection. If it hits the rough surface, the light is forced off in a random pattern giving a dull reflection that lacks depth. If the surface is smooth, the light hits cleanly and bounces off cleanly, giving a much deeper, cleaner reflection.
So, starting with a freshly washed car, break the clay into three pieces. You will not need a large lump and the other two will come in useful. Warm the clay in your hands and mold it into a flat pancake shape. Now, using the Quick Detailing spray, cover an area of around 2 feet x 2 feet and then gently rub the clay across the panel. You will feel and hear the contaminants. There will be a worrying scratching noise which you should ignore. This is the clay pulling the dirt out of the paint. The clay will bite aswell as you run along the panel. Once this frees up and glides smoothly, use a clean micro fibre cloth to wipe the excess QD spray off the panel. Repeat on the next section until the whole car has been done.
You can also clay glass and wheels to remove ingrained dirt .
You should normally leave a piece of clay in the wash bucket so that as you wash and find tar spots, you can clay them off. The car shampoo gives the lubricity needed. On painted alloy wheels, the clay will again remove ingrained brake dust in a similar fashion to the paintwork.
DO NOT USE THE SAME CLAY TO DO BOTH WHEELS AND PAINTWORK.
It is best split into three pieces.
Once finished with the clay, wrap it in some plastic or a resealable sandwich bag. One piece of clay should last around 3-4 complete clay sessions. For a car used daily, it is recommended claying once every 3-4 months.
It is also recommended rewashing the car after the claying to remove the lubricant film. Then go over it with a pre-wax cleaner to finish the cleaning process.
After this, it is also very important to seal and wax the paintwork, as the claying process will remove all previous wax.
Sealers and glaze products should be applied after paint cleansing and before the final wax stage. Glazes give the shine that everyone wants and the key is good preparation. This fills any minor swirls left and hides slight scratches, allowing the light to bounce off smoothly giving the depth of shine.
Always apply these products in the shade so as to prevent them drying out too quickly. Generally, glazes do not need to dry off, so can be removed straight away.
Once glazed, you will be ready to apply your choice of wax.
IF YOU DROP THE CLAY ON THE FLOOR, THROW IT AWAY.
DO NOT RE-USE IT.
Scotty
PostPosted: Sun May 04, 2008 6:38 am    Post subject: Reply with quote
Thanks JR, I've been wondering how clay bars worked, might even try one now that I have a guide as to how best to use it. Wink
PostPosted: Sun May 04, 2008 11:42 am    Post subject: Reply with quote
I'd never heard of it before. Sounds interesting. You've just got an eBay seller another sale.
Thanks,
Greeney in France
PostPosted: Sun May 04, 2008 6:45 pm    Post subject: Reply with quote
I use a good claybar from bilt hamber and it only needs water as its lubricant instead of a special
www.OldFrenchCars.com
Uncle Joe
PostPosted: Mon May 05, 2008 7:36 am    Post subject: Reply with quote
Of these suggestions, I have decided to try out the ones from Mothers. Most of the ones mentioned arent available here, so it did make my choice easier.
Now to find a car that I'm not to bothered about paintwise if the product doesnt work!
Job-Rated
PostPosted: Mon May 05, 2008 10:09 am    Post subject: Reply with quote
Trust me, Joe, I've seen the results after a good clay bar session & it is simply amazing.
You will not regret it.
Old-Nail
PostPosted: Mon May 05, 2008 10:57 am    Post subject: Reply with quote
Quote: "There will be a worrying scratching noise which you should ignore".. Ooh-err! Shocked Laughing
I must say I hadn't heard of claybars until recently, the process seems to work in the same manner as putty rubbers do to erase pencil marks. I think I might try this next time I have some jaded paintwork.
Norfolkandchance
PostPosted: Tue May 06, 2008 8:47 pm    Post subject: Reply with quote
Now I feel like I am billy no mates as I have always used Autoglym polish and their other products, but not the tyre dressing. I use' Back to Black' for that.
But the one thing I do which it I am sure does not say on the bottle is use a fairly damp cloth before I put polish on it thus using the polish more sparingly.
But what do I know...
Greeney in France
PostPosted: Tue May 06, 2008 9:28 pm    Post subject: Reply with quote
No thats fine I have used autoglym for years very satisfactorily.
It is only recently I have been experimenting with modern stuff.
I use a damp cloth too as it spreads the polish better
Rolls Royce, Aston martin and Jaguar are just a few that put their name to it
Rich5ltr
PostPosted: Wed May 07, 2008 2:53 pm    Post subject: Reply with quote
I also use mostly Autoglym products except for a few exceptions. I reckon that for general washing, cleaning and polishing they are good value and work well. So I use their car wash, interior cleaner, leather feeder, glass cleaner etc. What I do use however is P21 wax. It's about £20 a tub and equally as good as stuff like Swisswax and Zymol which are silly money. I reckon that to do a "proper" job involves washing the car with a proper car shampoo (not washing up liquid!), polishing it for which I use Autoglym and then waxing it. For tyres I use Wonder Wheels.
PostPosted: Mon May 12, 2008 3:09 pm    Post subject: Reply with quote
Thanks,
Well I just tried the Mother's Clay Bar and Carauba Cleaning Wax. I'm not yet convinced by the clay bar but the Carauba Cleaning Wax that came with it is really excellent. Easy to apply, requires minimum quantity, leaves no white dust residues. Definitely easier to use than Autoglym or Autoglym Finishing Polish.
Thanks JR, I'm sure I'll buy more of that stuff.
My lack of conviction about the clay bar may be due to my car's generally poor paintwork
KevF
PostPosted: Wed Nov 05, 2008 10:20 pm    Post subject: Reply with quote
Sorry its late in posting about this but one thing that I need to ask...
In almost all the posts, you mention polishing the car????
Please excuse me if I am about to offend anyones intelligence but there is a huge difference between a polish and wax. You shouldnt be polishing the car each time you wash especially on older paints that possibly have no clearcoat.
If the AutoGlym product you are using is the Super Resin Polish, this contains mild abrasives so each time you are using it, you are removing microns from the paint surface.
By using a wax, it is protecting the painted surface rather than removing anything.
I have to be careful not to go on too much as I am but a newbie here. Sorry.
I would recommend claying the paintwork if it has never been done. This will remove bonded on contaminants such as brake dust, air borne particles, tar spots etc.....once this has cleaned the surface thoroughly, then if the paintwork has faded or oxidised then you can use a polish.
now you can machine polish or hand polish here.
Next I would apply a good quality glaze. This glaze is what gives the depth and lustre to the finish. Basically it has fillers in it to fill and smooth any fine scratches or swirls (if you havent machine polished) thus leaving a smooth surface for light to refract off cleaner hence better, deeper reflections.
Now glazes and sealers are not waterproof so you need to lock in this product with a wax. There are many choices as outlined in the previous posts. the main kinds are natural Carnauba ones or synthetic Polymer resin ones. Each give a slight difference in appearance and longevitiy.
None of the products I use in either my personal or professional details contain silicone and the majority of the quality brands dont have them either. I tend to prefer Mothers (and sell it ahhemm) but use various and possible too many other products to achieve the desired results.
Again sorry if this comes across as teaching you to suck eggs but thought I would try and answer a few of the queries mentioned above.
Currently paint correcting and detailing a 1953 Porsche 365.
Job~Rated's mate - KevF
PS...if anyone would like more info (there is lots more..LOL then let me know)
Page 2 of 3
