Mg Midget - twin carbs query
eddie
PostPosted: Tue Jun 10, 2008 7:33 pm    Post subject: Mg Midget - twin carbs query Reply with quote
Hi pals, I have just purchased a 1967 MK 111 midget with twin su carbs what I don't understand is there is no vacuum advance can anyone tell me why. Also can anyone advise how to set the carbs as the engine idles lumpy contact breakers are ok spark plugs are new I am not certain about the timing it is a 1.275 cc I could do with advice on how to set that .
Edd
PostPosted: Tue Jun 10, 2008 7:43 pm    Post subject: Reply with quote
Hi eddie, welcome to the forum, I'll move this into the Restoration Tips and Advice category, see if anyone can help you out
cheers, Rick Smile
PostPosted: Wed Jun 11, 2008 2:44 pm    Post subject: Reply with quote
Hi Edd,
Welcome to the forum. When you say there is no vacuum advance do you mean that there is a diaphram on the distributor but you can't find a point to connect it to the manifold? Close-up photos might get more replies.
You might find this useful for setting up http://www.oldclassiccar.co.uk/balancecarbs.htm
Setting the ignition timing will be fairly straight forward and will be set out in something like the Heynes manual
http://cgi.ebay.co.uk/MG-AUSTIN-HEALEY-MIDGET-SPRITE-1958-1980-Haynes_W0QQitemZ220244145012QQihZ012QQcategoryZ36089QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I know Haynes manuals aren't perfect but if you haven't got anything better then it would be worth investing in a copy.
HTH
PostPosted: Wed Jun 11, 2008 3:47 pm    Post subject: Reply with quote
Hi Eddie,
I've recently been working on my Sprite and changed the distributors.
As you can see there is a diaphragm on the distributor and it should connect, by pipe, to the left of the left hand(front) carb, close to where it bolts to the manifold.
It will certainly run rough if this pipe is missing.
eddie
PostPosted: Wed Jun 11, 2008 4:49 pm    Post subject: Reply with quote
Hi Peter, There is no vacuum unit on the dissi at all !! I.am baffled
Eddie
PostPosted: Wed Jun 11, 2008 5:28 pm    Post subject: Reply with quote
Hi Eddie,
Is the body of the distributor designed to take a vacuum unit (like in pigtin's photo) but the unit is simply missing?
In some more modern distributors the body is a pressing rather than a casting and the vacuum unit just screws onto the side and a rod pokes through a hole to rotate the contact plate.
Another, most unlikely possibility Laughing is that your car has somehow been fitted with a pre-war distributor that never had any vacuum control. (Not a serious suggestion) Wink
PostPosted: Wed Jun 11, 2008 5:40 pm    Post subject: Reply with quote
Hi Eddie and welcome
A vacuum leak in the induction system can often cause a rough idle, which if the hose is missing might account for both problems.
eddie
PostPosted: Wed Jun 11, 2008 7:57 pm    Post subject: dissi Reply with quote
Hi Peter,
There is nowhere on my dissi . for a vacuum unit to attach.
So where do we go now its beyond me !!
Eddie
