Posted: Mon Jun 23, 2008 10:37 pm Post subject: |
Is it a valve spring compressor  _________________ ROVER
One of Britain's Fine Cars |
Greeney in France
Posted: Tue Jun 24, 2008 6:44 am Post subject: |
It looks like a bearing ring remover or replacer given strength by bolting on to something through those wings or a similar keyed ring nut  _________________ www.OldFrenchCars.com
wrinx
Posted: Tue Jun 24, 2008 7:58 pm Post subject: |
47p2 wrote: | Is it a valve spring compressor  |
It is, wondered if that might be too easy for you lot
For my old Matta. Had to make that in order to remove the valves and springs as they're threaded in to the top of the valve Press down and then turn the toothed bit to unscrew the tappets from the top.
This is from the manual....
Close up of the valves...
wrinx _________________ www.alfaromeo155.co.uk | www.alfamatta.co.uk
Posted: Tue Jun 24, 2008 8:53 pm Post subject: |
Not just a pretty face  _________________ ROVER
