Compression advice needed
PostPosted: Sun Aug 03, 2008 5:35 pm    Post subject: Compression advice needed Reply with quote
Fired up the Morris 8 for the first time in .. oh dear 4 years..Embarassed . Started no problem (and did it have 4 year old unleaded in the tank!!) but unfortunately just as I remember the exhaust had that rather too much of a blue colour. Anyway did a compression test when she had warmed up, and all cylinders were between 105 and 110 psi. With a dab of oil in each cylinder this rose to about 130 psi. I didn't bother with a leak down test as it appears that the bores are worn, but was wondering what the correct PSI should be, the workshop manual quotes 6.7:1 compression ratio but not allot else...
Any Ideas
Ta Dave
PostPosted: Sun Aug 03, 2008 6:40 pm    Post subject: Reply with quote
Are you sure the rings aren,t stuck?
Uncle Joe
PostPosted: Sun Aug 03, 2008 8:11 pm    Post subject: Reply with quote
UK, I need to check a little on this, but I would make a guess that the pressure is about right for that cr....
