Mystery objects
Roverron
PostPosted: Sat Aug 30, 2008 6:03 pm    Post subject: Mystery objects Reply with quote
Anybody recognise what these are(or were)? They are from my... Rover
PostPosted: Sat Aug 30, 2008 6:19 pm    Post subject: Reply with quote
Could you take the photo from a bit further away, so they are in focus, or is it that part of the challenge?
Laughing Like those "recognise this from an unfamiliar angle" quizzes. Laughing
peppiB
PostPosted: Sat Aug 30, 2008 6:29 pm    Post subject: Reply with quote
The way they are there, they look like spent air gun pellets!!
Roverron
PostPosted: Sat Aug 30, 2008 6:38 pm    Post subject: Reply with quote
If they were less fuzzy it would be too easy Laughing
PostPosted: Sat Aug 30, 2008 8:05 pm    Post subject: Reply with quote
Which Rover?
Rover P2
Morris Mini Traveller Mk2
62rebel
PostPosted: Sat Aug 30, 2008 10:38 pm    Post subject: Reply with quote
i'll hazard a guess that you found these in a very bad place; inside the combustion chamber? i'll then hazard that they are the missing washers from your air cleaners; the nuts possibly too heavy to be pulled into the carb throat, but washers light enough?
if not, then i'm scuppered as to what they are.
Roverron
PostPosted: Sun Aug 31, 2008 5:22 pm    Post subject: Reply with quote
Here is a better picture for those of you who are still puzzled. The big clue is the line which can be seen on the l/h one The Rover is a '46 ten
PostPosted: Sun Aug 31, 2008 5:29 pm    Post subject: Reply with quote
The remains of a small end and its bush?
PostPosted: Sun Aug 31, 2008 6:10 pm    Post subject: Reply with quote
The head of a slotted bolt, or self tapping screw
ROVER
One of Britain's Fine Cars
PostPosted: Sun Aug 31, 2008 6:28 pm    Post subject: Reply with quote
Is it valve heads?
Art
Roverron
PostPosted: Sun Aug 31, 2008 6:50 pm    Post subject: Reply with quote
Well done Art, they are indeed valve heads (both exhaust). The slot on the l/h one is for a screwdriver for grinding in the valve. The head broke off its stem, once in 1987 and another in about 1998, different cylinders. The inlet valves and the pistons hammered the heads into these shapes before I switched off/pulled up. On neither occassion was I going fast, both times about 45-50mph. I found the valve heads in the sump each time. Here is the piston from the first time which happened on the A1 on the way to Cambridge. Guess what I said at the time.
PostPosted: Sun Aug 31, 2008 7:34 pm    Post subject: Reply with quote
I expect you said something like I just did when I saw your last picture, not to be repeated in public however! Laughing Shocked
