Posted: Sat Sep 06, 2008 7:50 am Post subject: Chassis Paint |
The Morris 8 Chassis is away being blast cleaned at the moment at a place that only about a mile from my house, they are going to do it on a dry day (so may get it back this year given our current weather ) I'll etch prime it and then put a black top coat on.
Question
Want it to look "original" so pretty sure the black would not be high gloss? but also not a matt finish. Can I get paint made up in a semi gloss ? if so is there a correct term for the shade?
Cheers Dave |
Posted: Sat Sep 06, 2008 1:09 pm Post subject: |
The correct finish applied direct over bare metal (although phosphated would be even better) is Clorinated chassis black.
Frosts sell it _________________ Rover P2
wrinx
Posted: Sat Sep 06, 2008 2:40 pm Post subject: |
Would this be any good? Noticed my old beasty needs a fresh coat of something... Frost Chassis Black
Or,this Trade stuff
wrinx _________________ www.alfaromeo155.co.uk | www.alfamatta.co.uk
Posted: Sun Sep 07, 2008 11:17 am Post subject: |
Both those above are the same stuff and far superior to Hammerite as well as cheaper _________________ Rover P2
imfinlay
Posted: Sun Sep 07, 2008 1:09 pm Post subject: |
I wouldn't use gloss. I've ordered some of the Frost one, I'll post how it goes. I don't mind the satin smoothrite, but I hear it goes brittle. I've not found that myself yet though. |
Posted: Sun Sep 07, 2008 4:35 pm Post subject: |
Satin Smoothrite does harden and chip/flake off after 6-12 months. Proper Chassis Black is semi-gloss when fresh but dulls after a few months but not to a full satin finish.
The Frosts is nearest modern equivalent I think but the other one is likely to weather to same state if its the proper stuff _________________ Rover P2
Posted: Sun Sep 07, 2008 5:17 pm Post subject: |
Theres also the Bill Hirsch chassis paint as well. Personally I could think of either using powder coating, which is rather exact in terms of sheen, or over a media blasted chassis a Zinc base, with epoxy Mastic over that, and then something like black Dinitrol. Do it that way and it will never need doing again... |
wrinx
Posted: Sun Sep 07, 2008 11:52 pm Post subject: |
Phil - Nottingham wrote: | Satin Smoothrite does harden and chip/flake off after 6-12 months. |
That explains the state of my undercarriage then
Thanks, will buy some of the trade stuff
Posted: Thu Sep 11, 2008 1:27 pm Post subject: |
Wickes sell a mattish black paint that they call Wrought Iron paint. It makes similar claims as does Hammerite, but is a lot cheaper, easier to clean from brushes and seems to stand up to weather fairly well. Anyone else tried using it (other than on their fence)??
PAUL |
