Popular Wheel Bearings
Greg
PostPosted: Wed Oct 15, 2008 8:25 pm    Post subject: Popular Wheel Bearings Reply with quote
Just wondered if anyone would know the equivelant part numbers ,(not the Ford number), for Front, inner & outer wheel bearings for 1956 Ford Popular 103e?
Many Thanks,
Greg
PostPosted: Thu Oct 16, 2008 12:00 am    Post subject: Reply with quote
Hi Greg,
Unfortunately you are just a bit too modern for my sources but if you are familiar with part commonalities then this might help:
Ford 8HP & 10HP 1932 to 1952
Front inner SKF K07097-K07204 or Timken Y1201-Y1202 or Ford Part No. as Timken
Front outer SKF K03062-K03162 or Timken Y1216-Y1217 or Ford Part No. as Timken
Greg
PostPosted: Thu Oct 16, 2008 7:04 pm    Post subject: Reply with quote
Thank you very much Peter, I'll try to see if they're the same for '56.
thank you again, all the best,
Greg
PostPosted: Thu Oct 16, 2008 7:08 pm    Post subject: Reply with quote
could be worth having a look on the small ford site, see if they list the same part number(s) covering all years, including 56 or not, that might confirm whether Peter's numbers will apply to your car (I bet they do, I wonder if JRF has any info as he has a 103E too)
PostPosted: Thu Oct 16, 2008 8:17 pm    Post subject: Reply with quote
Hi Greg,
This club list doesn't appear to specify which cars the front bearing are for,
which rather suggests all. http://www.fsoc.co.uk/spares/810spares.pdf
Quote: "The club's spares lists include general items for 8 & 10 hp models from the 1930's Model Y to the 103E Popular as well as the E83w commercial and the 100E range and 107E Prefect."
1stpop
PostPosted: Thu Oct 16, 2008 9:47 pm    Post subject: Reply with quote
this guy is brilliant and helped me a lot when I had my 1955 103E
http://homepage.ntlworld.com/c.musson/
Its Pop Parts Plus - give him a ring
