geoffersgra
Posted: Tue Nov 04, 2008 8:27 pm Post subject: Riley Falcon Special |
This is my Riley Special.
I inherited it from my late Father who died suddenly before the car was finished. That was 12 years ago. The car has been stored since.
The car was originally a 1935 Falcon saloon that was a complete wreck. Dad worked on the car virtually full time after taking early retirement, he was an aircraft engineer and the car has been finished to a very high standard.
The car requires wiring & final engine assembly to get it going.
I was wondering if anyone out there is doing similar thing. I am no Riley expert so a helping hand would be appreciated.
Geoff Abraham
Bristol UK |
Posted: Tue Nov 04, 2008 9:41 pm Post subject: |
Welcome Geoff, What a cracking car.  _________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
euronerd
Posted: Thu Nov 06, 2008 12:31 pm Post subject: |
Lucky you, having inherited such a gem. The only thing I inherited from my dad was the book 'Riley Maintenance Manual 1930 - 1956', but it has wiring diagrams and engine assembly tips. This book, if you haven't already got it, is still in print, but you might need to join the Riley Register first. I can scan you the relevant diagram and stuff if you want.
Geoff. |
Posted: Thu Nov 06, 2008 1:44 pm Post subject: Re: Riley Falcon Special |
| geoffersgra wrote: |
Geoff Abraham
Bristol UK |
I do like that. I am an expert on my family, and they are called Riley, but probably not what you are after. hehe
I think a Riley of some sort is on the cards someday, just to have my surname on a car, would be pretty neat!
Posted: Thu Nov 06, 2008 1:46 pm Post subject: |
| Rick wrote: | This is the car I mentioned that lives not far from here (Cheshire). The car your father built looks superb!
Rick |
That Riley pic looks like it was taken in a familar place, is it where I think it is, if so why?
Posted: Thu Nov 06, 2008 9:21 pm Post subject: |
Ah I see, what else turned up? perhaps we should start a new thread, to save hijacking this one too much?
geoffersgra
Posted: Tue Nov 11, 2008 8:17 pm Post subject: |
Hi Rick & All
Thanks for the interest & comments. With regards to the wiring I have made a start using a Morris Minor diagram I know Dad was intending to use. My intention at this stage is to get the car running but not necessarily road legal so the wiring requirements for that are minimal. I have hit my first snag however, the voltage regulator I have is a Lucas RB340 which I assume is a modern solid state version of the original (no points to adjust) which does not have the same pin configuration & obviously function as the original. I have found a diagram for a 1968 MGB that uses a dynamo & the regulator I have so I may use that.
I'm sure there are some electrical experts out there who may be able to advise.
I will keep you posted as to the progress
Geoff |
Posted: Tue Nov 11, 2008 9:37 pm Post subject: |
Geoff,
The RB340 is not a solid state regulator. It's a very popular regulator from the 60/70s with three coils inside. One is the cut out and the other two are voltage and current regulators. These are in series with each other and provide the connection between the D & F terminals on the dynamo. The only drawback is that they should really be adjusted using a special tool which has a gear to turn the adjuster cam but the can also be by carefully grasping the cam with long nosed pliers. If you PM me I can scan you the procedure from a Jaguar MK II manual.
Posted: Wed Nov 12, 2008 11:47 am Post subject: |
Hi Geoff,
The RB340 is a very nice control box and much more intelligent than the old two spool varieties but do keep in out of sight as it's not really in period for that fabulous car of yours.
As to its connections they don't really differ that much from the older regulators. Here's the equivalence:
Old Style.......RB340
A & A1.............B
F.....................F
-.....................WL (This is for the ignition warning lamp)
D.....................D
E......................E
You just connect your warning lamp between the ignition switched supply
and the WL terminal on the RB340
Posted: Sat Nov 15, 2008 11:35 am Post subject: |
| What a lovely car. I hope you have it on the road for next spring/summer. Is that much fun legal? |
