Timstopp
Posted: Tue Nov 04, 2008 6:30 pm Post subject: 1934 headlights - MOT |
My car has the lucas dip on one side, which then turms off the headlight on the other. I have just spent all day getting this to work(which it does nicely) Someone passing pointed out that this is now illegal.
Is it true that although standard fitment in 1934, I now have to change - and to what, they are 8 inch rims?
Thanks
tim _________________ North Essex,UK - Morris 8 tourer 1936 - Jaguar x350 |
Posted: Tue Nov 04, 2008 6:59 pm Post subject: |
Timstopp,
The easiest solution would be to find another dipping solenoid and fit that. Then you will have double dipping headlamps.
Posted: Tue Nov 04, 2008 7:16 pm Post subject: |
My 1932 Austin 10/4 had those headlights, didn't even try to use them because of test. Fitted some adaptor rims for a while and used Lucas 700 type units with a relay operated from the steering hub dipswitch to dip them together, used to use it at night regularly. These days I have standard looking reflectors both set in the dipped only position. Had no trouble with the MOT for the last ten years.
Don. _________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
Timstopp
Posted: Tue Nov 04, 2008 9:02 pm Post subject: |
aaahhh
Don, so you are saying that if my headlights are on dip only ie not dazzling oncoming traffic, I am OK? (the dipping mechanism is easily disabled) _________________ North Essex,UK - Morris 8 tourer 1936 - Jaguar x350 |
Posted: Tue Nov 04, 2008 9:32 pm Post subject: |
Had no trouble with two different test stations over the last ten years or so, but there's always the chance that one may put a different interpretation on the rules. So best check with them first.
Posted: Tue Nov 04, 2008 10:26 pm Post subject: |
Most MOT testers are sympathetic when it comes to testing old cars. I always give the reason "It was built that way so it isn't required"  _________________ ROVER
One of Britain's Fine Cars |
Posted: Tue Nov 04, 2008 10:41 pm Post subject: |
Rick, you might like to put this link somewhere suitable as a sticky so that the manual is quickly accessible for everyone.
http://www.motuk.co.uk/manual/contents.htm
Apologies if it is already here somewhere. |
Posted: Tue Nov 04, 2008 11:05 pm Post subject: |
Hi Tim,
I did the same as 47jag has suggested and it has proved reliable for the last 15 years and keeps MOT testers happy. It's also a nice piece of archaic technology that amuses folk at shows etc.
It's very easy to arrange because you'll find that the non-dipping side has the bracket etc for the solenoid and these are commonly available at autojumbles.
Before I got my second solenoid I did try fitting double filament bulbs but if you focus correctly for one filament you'll find the other is wildly wrong.
Posted: Wed Nov 05, 2008 10:03 am Post subject: |
The dip and switchoff arrangement has been illegal for over 60 years and its not a matter of interpretation now of MOT rules - just lack of knowlege by the tester. However 1936 was the cut-off date for most retrospective lighting
Having said that my own 1938 Rover 16 had full MOTs' till 1996 when I bought it with a variation of this arrangement where the offside diped and nearside went out and was replaced by a low mounted "pass lamp" that is usually mistaken for a fog light - I did convert it to double dip however or safety.
Older cars like mine with the big headlamps were catered for by conversion rims to use the Lucas 7" pre-focus bulbs. I just obtained a double contact bulb holder to use a standard 36/36w double filament bulb as was standard fit in the o/s head lamp as Rover never trusted the unreliable solenoid reflector tilt device even then _________________ Rover P2
Posted: Wed Nov 05, 2008 4:52 pm Post subject: |
According to the manual 1931 is the cut off date for mandatory retrospective fitting of double dipping headlights.
| Quote: | A "matched pair" is a pair of lamps which
. both emit light of substantially the same colour and intensity, and
. are both the same size and shape, so that they are symmetrical to one another.
Note: Pre 1st January 1931 Vehicles
For vehicles that are fitted with one or two optional headlamps;
. where one is fitted it must dip
. where two are fitted, either both must dip or one must dip and the other switches off.
and both dipped and main appear to be mandatory.
| Quote: | 1. Check that the vehicle is fitted with obligatory headlamps, as follows
a. a matched pair of main beam headlamps, and
b. a matched pair of dipped-beam headlamps
Note: Main-beam and dipped-beam functions may be provided by a
single pair of headlamps.
Posted: Wed Nov 05, 2008 5:48 pm Post subject: |
Gawd! Don't let my MOT test station know.  _________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
Posted: Wed Nov 05, 2008 6:35 pm Post subject: |
Well as I said its not a matter of opinion its a matter of law so whether or not it is broke it has to be fixed! _________________ Rover P2
dalbuie
Posted: Wed Nov 05, 2008 7:36 pm Post subject: |
It's also law not to use your mobile phone while driving but I don't see that stopping anyone  |
Timstopp
Posted: Thu Nov 06, 2008 12:13 am Post subject: |
I have checked the non dipping headlight, and it cannot be converted without a whole new inside, so it would appear my only option is to araldite a 7 inch modern unit and hack the wiring to bits, or hack off the headlights altogether and fit something modern.
Thats no way to treat an old car!
i may try to get a "daylight hours only" MOT - I believe these do exist) _________________ North Essex,UK - Morris 8 tourer 1936 - Jaguar x350 |
dalbuie
Posted: Thu Nov 06, 2008 12:22 am Post subject: |
| Quote: | | except those which either have no front or rear position lamps or have such lamps permanently disconnected, painted over or masked |
Means you'd need to disconnect everything. Best to just put it in for the test - there's a good chance the examiner won't pick anything up. |
