Lodge & Autolite spark plug reference books
PostPosted: Fri Oct 17, 2008 9:45 pm    Post subject: Lodge & Autolite spark plug reference books Reply with quote
Has anyone got either reference book to hand?
The Dodge originally had Autolite A7A plugs in it, but they seem thin on the ground. Lodge was one of the sponsor logos on the side, so if I can't find a suitable Autolite plug (Autolite #303 or #306 has been suggested elsewhere), then an equivalent Lodge plug would be appropriate, if I knew what I was looking for!
thanks, R
PostPosted: Fri Oct 17, 2008 9:59 pm    Post subject: Reply with quote
My P2 was originally meant to run on Lodge plugs. I eventually managed to track down a set, but before fitting them I spoke with one of the P2 experts and was told it would not be a good idea
I would be careful if fitting Autolite or Lodge plugs to your car. Modern fuels burn at a much hotter temperature than they did when your vehicle was manufactured. Older type plugs cannot cope with the heat generated and the plugs will foul up and cause the car to run rough, maybe even cause a breakdown.
ROVER
One of Britain's Fine Cars
PostPosted: Fri Oct 17, 2008 10:07 pm    Post subject: Reply with quote
Thanks for that p2, good points - I've sent the question off to a friend who has restored a number of Dodge trucks, see what he fits in his!
cheers, R
PostPosted: Fri Oct 17, 2008 11:01 pm    Post subject: Reply with quote
The NGK website has a comprehensive equivalence chart but no Lodges on.
On our Rover P4 100 although the correct type Lodges fouled up on unleaded so always use NGK's or Bosch after equally unreliable experiences with Champions on this car and P5/P5B's
Rover P2
Morris Mini Traveller Mk2
PostPosted: Fri Oct 17, 2008 11:44 pm    Post subject: Reply with quote
Hi Rick,
I've emailed some Champion cross reference and heat tables to you but I'm not sure they are very helpful for your Dodge.
PostPosted: Sat Oct 18, 2008 8:22 am    Post subject: Reply with quote
Thanks for them Peter, handy things to have 'on file' Smile
cheers,R
Jim Walker
PostPosted: Fri Nov 07, 2008 10:20 pm    Post subject: Reply with quote
This thread puzzles me. Why do I not have sparking plug troubles? I run my unmodified cars and motorbikes on unleaded and have done for years, using the recommended plugs. I don't care whether they are Champions or Bosch or whatever as long as they are the correct reach and heat range.
Could it be that I USE my vehicles? That I don't start them up every few days to make sure they still run? Or that, having started them, I don't turn them off until they are thoroughly warm? Nor do I leave them idling for long periods.
Oh, and before anyone asks, I have yet to find any problems running on un-leaded, and if I ever do I must have saved enough money to have valve seat inserts fitted many times over.
Jim.
PostPosted: Fri Nov 07, 2008 11:49 pm    Post subject: Reply with quote
I agree - its nothing to with unleaded fuel and probably its with how the car is used - I have always found Champion plugs less reliable even when petrol was dripping with lead
Rover P2
TonyBrooks
PostPosted: Wed Nov 12, 2008 1:24 pm    Post subject: Reply with quote
Have a look here
http://www.gsparkplug.com/
PostPosted: Wed Nov 12, 2008 10:54 pm    Post subject: Reply with quote
Absolutely agree with Jim Walker. Only start the cars when I'm going to use them and never start them up "just for fun", or to let a fellow Club Member "hear" how good my engines run!
I've never had the remotest trouble with unleaded fuel. Leaded fuel in West Oz was discontinued about 2001 which was supposed to herald the end of the known world. We had "experts" creeping out of the woodwork, all telling us that we should do this or do that etc. It's all became too hard. Just drive the dammed cars! I've never had any valve problems associated with lead free fuel yet. I'll worry about problems when they happen!
Our unleaded is 91 octane (lower than yours) and the only old car I have that doesn't like it is the A40 with a 1622 BMC series B motor. I run that on 96 octane.
As far as plugs go, I very rarely touch them. We drive long journeys on fast empty roads and only do about 2000 miles a year so they are troublefree for years.
PostPosted: Thu Nov 13, 2008 7:00 pm    Post subject: Reply with quote
TonyBrooks wrote:
Have a look here
Thanks for reminding me of them Tony, their catalogue looks very handy
