filler and 3m panel adhesive
Greeney in France
PostPosted: Wed Dec 10, 2008 3:32 pm    Post subject: filler and 3m panel adhesive Reply with quote
Does anyone know if it is OK to apply filler over the top of a 3M PU panel adhesive, is it compatible and will it attach itself adequately?
www.OldFrenchCars.com
magic9r
PostPosted: Sat Dec 13, 2008 11:37 pm    Post subject: Reply with quote
If you are filling over an adhesive on a panel seam you will run the risk of the filler cracking if there is any scope for the panel to flex from vibration etc.
What vehicle, where on the vehicle & what are you trying to achieve?
Regards,
Nick
Greeney in France
PostPosted: Sat Dec 13, 2008 11:52 pm    Post subject: Reply with quote
Its on my Merc G Wagen, I was doing a bit of forest surfing and ripped the wheel arch off, so have repaired the section by welding in a new up to a panel seam that was originally filled, on the back of the receding lip, I used panel adhesive to fix it as it was almost impossible to get the weld gun in the confined space I used Terostat 9220, there isnt alot showing just a seam of 2mm by about 600mm
The body doesnt flex much as it has separate chassis and its a G Wagen Embarassed Laughing but wasnt sure if the filler would stick to the seam and eventually drop off
Thank you
magic9r
PostPosted: Sun Dec 14, 2008 10:30 pm    Post subject: Reply with quote
Use polyeurethane adhesive sealant like Sikaflex applied with a nozzle trimmed at about 45 degrees, use panel wipe on a fine cloth to clean off excess and smooth.
Overpaintable & it will never crack.
You could fill leaving a small gap (or cut the gap by hand with a hacksaw blade after filling) & use sealer to fill the gap,
Nick
Greeney in France
PostPosted: Sun Dec 14, 2008 11:16 pm    Post subject: Reply with quote
Thanks Nick a great help
