TonyBrooks
Posted: Mon Dec 29, 2008 10:15 am Post subject: Installing a 4 Speed gearbox in an E93A? |
| I am considering the engineering challenge of changing my 3 speed gearbox in my Typhoon to a 4 speed gearbox. I wish to keep the same E93A engine and do not wish to alter the present torque tube arrangement. An old 50's tuning manual recommends using an MG 'J2' gearbox which can " be bought from a breakers for £2" !!!! Other methods have suggested using a 105E gearbox with a suitable spacer (Smallford Spares sell them) but then I would need to change the diff in the rear axle to allow a prop shaft arrangement and then find a different way of relocating the rear axle. In the perfect world I want to find a gearbox that I can modify the bellhousing to mate to my engine and modify the prop shaft outlet to mate to my torque tube. Any advice greatly appreciated. |
James_1
Joined: 13 Jun 2008 Posts: 15 Location: Tunbridge Wells
Posted: Mon Jan 19, 2009 9:19 pm Post subject: |
| I'm also looking at doing a conversion like this at the moment and I'm looking into fitting a four speed to my E93A special and I'm looking at fitting a Austin 7 gearbox to mine. I know that E93A engines were often fitted to A7 chassis so it can't to too difficult to do. I have also looked at a Reliant Robin 'box as they are very cheap and are the right size, although these are alloy so a plate would have to be made up. I'll post anything else I find. |
Joined: 16 Oct 2008 Posts: 1206 Location: Upper Swan, Western Australia
Posted: Tue Jan 20, 2009 1:19 pm Post subject: |
Hey James
Austin Seven gearboxes were all 3 speed until September 1932. The first 4 speeds were crash boxes, so make sure you get one after August 1933.
Keith D |
