Posted: Tue Jan 06, 2009 11:45 pm Post subject: Lotus Engineering Engine Simulation |
Fancy changing some of your engine's design parameters? See the effects of your changes in the Lotus freeware simulation..
http://www.lesoft.co.uk/index1.html
The freeware only allows one cylinder but you can just multiply the numbers by your own cylinder number even if that is an over simplification.
I thought I'd try entering my data to see the effects of different valve timing.
You can read why here http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=5887&start=105
I tried 16,56,56,16 which should be the timing for my engine then 10,50,50,10 which is what I have been running with. The simulation does show the increased torque and reduced power of the second timing but the effect is less than I expection so I then tried a more extreme example of 0,30,30,0. _________________ https://www.nostalgiatech.co.uk
