Midget Choke -----HELP
Finch661
PostPosted: Thu Feb 19, 2009 3:03 pm    Post subject: Midget Choke -----HELP Reply with quote
i am tinkering away with my 76 mg midget, but i am having some troubles with the choke. it seems that after about a week, the locking part is stripped, hence it does not lock. i am using the peg system for now, but i am wanting something a bit more perminant!
i was thinking of removing the mixture return springs then using a simple push/pull system, as seen on the classic mini for its heat control.
any thoughts on the matter?
thanks
rich Sad
PostPosted: Thu Feb 19, 2009 5:53 pm    Post subject: Reply with quote
Hi Rich, why not just buy a new choke cable and surround? sounds a lot easier to me
Rick (OCC Admin)
Finch661
PostPosted: Fri Feb 20, 2009 9:30 am    Post subject: Reply with quote
true, a very easy solution, but i have gone through 3 cables in the last 3 months. the average life is about 1-2 weeks..... quite annoying
PostPosted: Fri Feb 20, 2009 9:43 am    Post subject: Reply with quote
by eck - are they modern repro ones?? if so might be worth trying to source an original unused BL part maybe?
Rick (OCC Admin)
Kelsham
PostPosted: Fri Feb 20, 2009 5:06 pm    Post subject: midget choke Reply with quote
Why are the cables failing? you do have a good earth strap to the engine. If this has a poor connection the return electrical path can go through the choke cable and cause it to heat up.
regards Kels.
PostPosted: Fri Feb 20, 2009 5:45 pm    Post subject: Re: midget choke Reply with quote
regards Kels.
Good point Kels, I have also seen the same thing happen with throttle cables; glowing red as they try to deliver a few hundered amps! Shocked
If it is a manufacturing fault with the cables, what is the suppliers veiw?
PostPosted: Fri Feb 20, 2009 5:48 pm    Post subject: Reply with quote
Also make sure the cable is in as straight a run to the carb as possible
ROVER
One of Britain's Fine Cars
Finch661
PostPosted: Sat Feb 21, 2009 1:21 pm    Post subject: Reply with quote
like i said, the choke doesnt lock when pulled out and twisted, it is completely stripped. it works great for about a week, then it slowly fails.
Rich5ltr
PostPosted: Sat Feb 21, 2009 7:45 pm    Post subject: Reply with quote
You need one of those spring operated choke control locking clips, I'm sure I saw one here a few days ago? Smile
Finch661
PostPosted: Tue Feb 24, 2009 12:22 pm    Post subject: Reply with quote
well im using a peg at the moment, just wanted something a little bit more permanant (oh and i am using a lightened polycarbonate spring loaded choke locking clip........ a plastic one....) Laughing
Scotty
PostPosted: Tue Feb 24, 2009 1:23 pm    Post subject: Reply with quote
Hi Rich,
I had a 1975 Midget and if memory serves me correctly it was a "pull and twist" to lock the choke out at the desired position. Is it the "twist" that's wearing out?
Scotty.
Finch661
PostPosted: Tue Feb 24, 2009 3:48 pm    Post subject: Reply with quote
yeah its the twist part. it works great with a new cable, but after a coupe of weeks it twists but then slips. very annoying! im using a clothes peg at the mo, i wnated to know if there is a conversion or a different type of choke mechanism i can use. i have an old mini aswell, that has no troubles
PostPosted: Tue Mar 03, 2009 12:10 pm    Post subject: Reply with quote
I have just been looking at an operators manual for a Wolseley 15/50 and have noticed this instruction for when refitting the choke cable.
Give the inner wire a clockwise twist (looking from the end) before tightening the locking nut/bolt.
This ensures correct function of the control locking device.
The picture shows the inner cable as a Bowden twisted cable and this would appear to be utilising the cable's natural tendency to straighten as a means of keeping the choke pull end in the locking position.
