James_1
Joined: 13 Jun 2008 Posts: 15 Location: Tunbridge Wells
Posted: Fri Jul 18, 2008 6:57 pm Post subject: E93A: Weber or twin HS2 |
I was considering fitting a 40 DCOE Weber carb to my E93A special. With a would this be suitable and would it need 36mm chokes? Has anyone ever fitted a Weber to a sidevalve engine? On the other hand I have a pair of rebuilt HS2s but I am not sure about fitting these because of tuning, I have had nothing but trouble in the past keeping twin carbs running right and the car is going to be used very regularly, hopefully everyday so it needs to stay in tune!
Thanks
James |
ka
Posted: Wed Aug 06, 2008 8:17 am Post subject: Carbs |
Depending on how "origonal" you would like the car to look. I run both a single 1 1/4" , and twin mini carbs and have found the power output to be very little difference. I am sure that there are people out there that can quote exact figures, but I find the single carb marginally more torquey than the twin set-up, possibly down to the greater gas speed, and similarly as the side valve is not a high revver, the single carb probably does not get beyond its gas flow limits. Other set ups I have tried are the early single 1 1/4" Webber carb from the Mk1 Fiesta, this has an acceleratior pump as an advantage, but is not so easy to set up as the SU. Other options I have tried are the 1 1/2" SU, to try and overcome the limitations on the smaller carb gas flow speeds.
Best outcome for me has always been the smaller SU, and the most economical!
KA |
James_1
Posted: Sun Aug 31, 2008 1:10 am Post subject: |
Thanks very much for the infomation KA. I really appricate it. I will fit the HS2s I've got lying around. |
Graeme
Posted: Mon Feb 23, 2009 11:52 pm Post subject: |
I know this thread is old, but i built a fully tuned up 10hp engine for my 49 anglia, with twin 1.5" su's.
Went very well!
I had 75mph out of it (on private roads ) |
