Waterpump / Footpump
yorkshireretro
PostPosted: Sat Apr 04, 2009 9:42 pm    Post subject: Waterpump / Footpump Reply with quote
I bought a tiny 70's 10ft ci Cadet caravan today and it has the old style water foot pump which sucks up water from a tank at the back of the caravan when you pump it. I tried it and it didnt suck anything up!! any ideas anyone? Smile
PostPosted: Sat Apr 04, 2009 10:57 pm    Post subject: Reply with quote
They usually have a rubber flap valve in them which may be worn. Try hand priming the pump first to see if it works
ROVER
One of Britain's Fine Cars
emmerson
PostPosted: Sun Apr 05, 2009 5:52 pm    Post subject: Reply with quote
As 47p2 says, it's probably just dried out from lack of use. Give it a soak and it should be OK
Brian M
PostPosted: Sun Apr 05, 2009 7:20 pm    Post subject: Reply with quote
Had one on my previous Knowsley, and my local camping shop had a refurb kit with new washers, valves etc.
You can replace it with the Whale electric submersible pump that you drop into the outside water tank.
Brian
