MGBGT V8 help needed
VTMG
PostPosted: Wed Apr 29, 2009 6:59 pm    Post subject: MGBGT V8 help needed Reply with quote
I am new to ownership of a 1975 V8 and today after a 20 mile run I parked the car on the drive and a few minutes later found about a cupfull of water(?) beneath the gearbox. This has never happened before. I have only owned the car for a month and done a couple of hundred miles in it thus far.
Any ideas where this water came from? The car has been well maintained. On lifting the bonnet I did notice a ltiny bit of water beneath the heater unit. Should I be worried?
thanks
Van
Nottingham
PostPosted: Wed Apr 29, 2009 7:32 pm    Post subject: Reply with quote
Clean water or dirty water?
Have you washed the car and moved it?
Used the windscreen washers?
Been out in the rain?
Has it lost coolant?
The Rover Alloy V8 must have strong fresh anti-freeze in it not plain or dirty water.
Also change oil every year or 3000 miles whicever comes first
Rover P2
Morris Mini Traveller Mk2
VTMG
PostPosted: Wed Apr 29, 2009 8:12 pm    Post subject: Reply with quote
Hi, it was sunny today in Nottingham-so it was not rain! I haven't just washed it either. However I did use the windscreen washers briefly by accident whilst on my journey. The water was a tiny bit oily although I wonder if that was because it was dripping off the gearbox which itself is a little bit grubby.I'll check that and the coolant.
cheers
Van
Dirty Habit
PostPosted: Wed Apr 29, 2009 8:38 pm    Post subject: Reply with quote
Heater matrix?........don't know where they are on a "B" but it may be worth a look.
1964 International Harvester
VTMG
PostPosted: Wed Apr 29, 2009 8:39 pm    Post subject: Reply with quote
cheers
Van
Coolant was low-I have topped it up-I'll monitor the situation.
Van
VTMG
PostPosted: Thu Apr 30, 2009 8:09 am    Post subject: Reply with quote
cheers
Van
Van
Anyone any ideas why the coolant should be so low?. No leaks that I can detect, and no mayonnaise in the oil either.
thanks
Van
PostPosted: Thu Apr 30, 2009 9:46 am    Post subject: Reply with quote
Welcome to the forum.
The combination of low coolant level and the water underneath does rather suggest a leak. You'll just have to try and trace the path of the leak back to
its source.
PostPosted: Thu Apr 30, 2009 10:02 am    Post subject: Reply with quote
Maybe try the washers briefly with the car sat on the drive, engine not running, and see if the same drip on the driveway underneath appears? it may just help tick that one off the list??
Talking of leaks, a friend of mine had a CA Bedford camper a couple of years ago and he was losing coolant slowly. It was a tiny drip, I think from the top hose, and the fan was blowing the droplets away and drying them, so that it was really tricky to spot where the leak was.
PostPosted: Thu Apr 30, 2009 1:19 pm    Post subject: Reply with quote
I had a pin hole leak which only dripped when under pressure unfortunately it was directly above the exhaust manifold so evaporated immediately as well.
Eventually found it by squeezing the top hose while stationary with a hot engine.
PostPosted: Thu Apr 30, 2009 8:38 pm    Post subject: Reply with quote
Check all hoses and clips carefully these cooling systems run at high pressure 15lbs and soon leak - hardened hoses will burst.
There is a steel water pipe under the inlet manifold in the valley - this corrodes from inside out leaving pits which eat their way through
Rover P2
VTMG
PostPosted: Fri May 01, 2009 6:42 pm    Post subject: Reply with quote
I think I have found the leak-it is the heater valve-at least that is where the water is coming from. I've ordered another valve and will have a go at fitting it when it arrives.
Thanks for all the advice
Van
PostPosted: Fri May 01, 2009 11:24 pm    Post subject: Reply with quote
A lot cheaper than dismantling the engine!
Rover P2
VTMG
PostPosted: Wed May 06, 2009 2:43 pm    Post subject: Reply with quote
One new heater valve and all seems well...
Van
