caravan floor replacment (materials)
vikingfibreline68
PostPosted: Fri May 22, 2009 2:11 pm    Post subject: caravan floor replacment (materials) Reply with quote
I need to replace the floor on my Viking Fibreline, i have looked at marine ply but its very expensive, exterior ply is cheaper and normal ply is cheaper still. could i get away with a cheaper ply and seal it with something.
All the best caravans have glass windows
captinbash
PostPosted: Wed Jun 03, 2009 10:55 am    Post subject: caravan floor replacement Reply with quote
Hello, You can use exterior plywood, get the best that you can find and then seal the edges with epoxy resin to prevent moisture getting in via the end grain, it is worth painting the underside with resin also and then painting for long term protection.
gillberry
PostPosted: Wed Jun 03, 2009 10:59 am    Post subject: Reply with quote
On our Cheltenham Nyala I'm using a ronseal exterior varnish on the underside to give a weatherproof seal .
vikingfibreline68
PostPosted: Mon Jun 08, 2009 12:19 pm    Post subject: Reply with quote
Thanks for the replies, exterior ply with sealer and epoxy resin for the ends sounds ideal
