Tyre size
andywen8156
PostPosted: Sun Jun 14, 2009 8:55 pm    Post subject: Tyre size Reply with quote
Hi is it possible to replace the 4.50 x 17 on my morris series e with 5.50 x 17 would the extra width cause a problems? thanks
PostPosted: Mon Jun 15, 2009 1:36 pm    Post subject: Reply with quote
Check very carefully that your Morris rims are wide enough for this much larger tyre. This is a safety issue.
The overall diameter will probably be larger giving the car a slightly higher top speed but with slower acceleratiom.
Also be aware that they will probably foul the mudguards (inner and outer) when the car is on full lock and make is neccessary to increase the turning circle of the vehicle by restricting the full lock of the car.
Keith
andywen8156
PostPosted: Mon Jun 15, 2009 2:59 pm    Post subject: Reply with quote
Thank you keith that is so very helpful indeed, I wonder if its possible to fit the 5.5 x 17 on the rear and the 4.5 x on the front would that be okay for the mot? thanks once again rgds andy
PostPosted: Mon Jun 15, 2009 3:18 pm    Post subject: Reply with quote
You could fit two different tyre sizes so long as the same size tyres are on the same axle. The problem comes when you get a puncture and only have one size spare. Shocked
ROVER
One of Britain's Fine Cars
andywen8156
PostPosted: Mon Jun 15, 2009 3:52 pm    Post subject: Reply with quote
That's a thought thanks for the advice rgds andy
MartinC
PostPosted: Wed Jul 29, 2009 9:06 am    Post subject: Reply with quote
Your proposed size is 1 inch wider. Will bulge from the rim a bit but should be okay at 1/2" per side. Especially as you say, if only at the rear.
The MoT has nothing to do with tyre sizes so will be fine.
As said, the spare will be odd, but this is no different to most modern cars with a space saver spare.
1937 Standard Flying Twelve
1942 Bedford OYD
1954 Hillman Minx
1956 Austin A30
1957 Vauxhall Victor Super
1962 Car Cruiser Carissima caravan
