Have a RANT
Nic Jarman
PostPosted: Tue May 05, 2009 8:32 pm    Post subject: Have a RANT Reply with quote
Why do people change the engine oil but not the gearbox oil or diff. Why do people put the wrong spark plugs in an engine, do they think they are more clever than the manufacturer? Well do they? You should have seen the rubbish that came out of the CBR600's forks, it makes me want to spit. Do some people think that putting a few holes in an old air filter will make it OK, I say to the feeble minded bodgers - NO. Do the right thing or buy a Ford Mondeo. Um I feel better for that and my spleen is suitably vented.
PostPosted: Tue May 05, 2009 10:03 pm    Post subject: Reply with quote
hehe, that sounded like you have had a great day! I often have days like that, wonder why you bother etc! hehe
the fly
PostPosted: Tue May 26, 2009 9:21 pm    Post subject: Reply with quote
Nik it apears that some are too idle to do a good sound job others have not enough knowledge and that can be a dangerous thing.when Iworked on bikes for a living i often had to pick up bent bikes [ 1936 350 norton float ] one very bent tiger 8o had a bottom girder fork spindle sheard the 18 year old rider had not survived .when checked by the authorities the spindle was found to be made from silver steel . A big mistake .Regards Les
PostPosted: Tue Jun 02, 2009 10:27 am    Post subject: Re: Have a RANT Reply with quote
Nic Jarman wrote:
Why do people change the engine oil but not the gearbox oil or diff. NO. Do the right thing or buy a Ford Mondeo. Um I feel better for that and my spleen is suitably vented.
Hmmm! I think the environment in the gearbox or rear axle is much more benign than that in the engine where oil gets contaminated by combustion products. My everyday transport is a 1993 Mondeo diesel and I've religiously changed the engine oil with part synth throughout its life but I've never changed the gearbox oil and I'm fairly certain it still contains the oil that was supplied in the factory 16 years ago. With 123,000 miles on the clock the gearbox and final drive are just as quiet as they were when I bought the car and synchromesh just as effective. Why should I be changing the oil?
p.s. My old Jag doesn't run with a gearbox that is dry on the outside so it gets as much attention as the engine. Wink
PostPosted: Sat Jun 27, 2009 11:05 pm    Post subject: Reply with quote
I'm surprised no one mentioned that many years ago Ford thought rear axle oil changes were so unnecessary that they even stopped fitting a drain plug.
lowdrag
PostPosted: Wed Jul 15, 2009 9:48 am    Post subject: Reply with quote
Interestingly, my Mercedes has a "sealed for life" gearbox. Then I started reading about Jaguar going back on that for their Merc sourced boxes and recommending an oil change every 60,000 so I spoke to the dealer. They changed the gearbox and diff oil and I'm glad I had it done - the colour was appalling. Engine oil is supposed to be every 12,000 but I do it at 6,000 just in case too, it being a dismal not petrol.
Nic Jarman
PostPosted: Wed Jul 15, 2009 10:15 pm    Post subject: Reply with quote
The oil in the diff came out in lumps and the gearbox was not much better. It is better to change it and be safe as most of our cars are well past their sell by date. Oil contains volatile components and "dries out" in time. "It is better to do it and not need it than need it and not do it" I think that was Confucus.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
