Vin number location for a 1949-1951 Jaguar Mark 5 for sale..
jellybean
PostPosted: Mon Jun 22, 2009 2:59 pm    Post subject: Vin number location for a 1949-1951 Jaguar Mark 5 for sale.. Reply with quote
Im looking for the VIN number on a Jaguar Mark 5...Im trying to get a registration for it...Some paperwork says 1949 but it looks like it may be a 1951...Anyone's help is appreciated greatly...
PostPosted: Mon Jun 22, 2009 5:59 pm    Post subject: Reply with quote
Hi JB,
The chassis number is stamped at the front of the near side (left) chassis leg.
If it's a 2.5litre saloon it will have the form 520001 RHD or 527001 LHD.
If it's a 3.5litre then 620001 RHD and 627001 LHD.
The engine number is stamped on the boss that projects out from the block on the exhaust side towards the rear just below the head gasket level.
HTH
jellybean
PostPosted: Tue Jun 23, 2009 1:44 pm    Post subject: reply to request for chassis/vin # on 1949/51 Mark 5 Reply with quote
Thanks for the information. I still couldnt locate any numbers, but Im sure I wasnt looking in the right place
...Could you be even more specific (for an idiot like me) on the "exact" location...Can I see it from above the engine block? Or on the ground looking up? Left or right side? Is it by the front left tire? I have some idea but I dont quite know what chassis leg is? What is near the location?
Thanks again so much...Am trying to get a title for the car...
PostPosted: Sat Jul 04, 2009 8:06 pm    Post subject: Reply with quote
Hi JB,
I'm sorry but I can't be any more specific. I was just quoting from the workshop manual. If it's like earlier Jags then it will be on LHS vertical face and could be anywhere from the jacking point back to the suspension. Also, if like earlier cars the lettering is quite big possibly 1/2" high numbers. Might be worth having a good scrape at it.
There are a lot of Mark V owners on http://forums.jag-lovers.org/index.php3?zx=SdAHzxPwzKPOC706QMnO%2F0j8Fj7Yy8NKAv8x0dkDD846B5uW%2BAnPC%2F7WnswK0BJIn5%2FHBMoR%2F96cyQLHCQCYx7gN
I'm sure you'll get the answer there.
HTH
jellybean
PostPosted: Thu Jul 16, 2009 2:27 am    Post subject: Mark 5 Engine # question Reply with quote
Hello, we got a Mark 5 that needs A LOT of work...We arent able to find too many numbers on the car,...but the number on the firewall is clearly g8243...Could someonetell me if this is a 1949, 50 or 51 based on this number...your help is appreciated
PostPosted: Thu Jul 16, 2009 7:09 am    Post subject: Reply with quote
have you tried contacting JDHT? they may have the specific info you need?
http://www.jdht.com/html/Trust/my_jaguar/myJag.html
PostPosted: Thu Jul 16, 2009 9:11 am    Post subject: Reply with quote
I suspect that G8243 is the body number. On the earlier Jags the body numbers were on little metal plates with embossed characters. There was no other information on the plate and you would find similar plates on the inside of the doors after removing the door cards.
